Foglight & License Plate Light UPG
Help me out here, but I think iJDM sent me the wrong bulbs for the license plate. They are the same size as the parking light and eyelid bulbs they sent me. If you look at the picture, after I installed the bulb, I cannot put back the plastic cover. Please let me know what bulb I should have received. I was under the impression the LED bulb for the license plate would have had all the LEDs pointed downward on the license plate, and not on the sides. (Sorry, the car is a little dirty from salt).
http://store.ijdmtoy.com/High-Power-...t10-sku318.htm
***One word of advice, the license plate socket on these GLKs is quite short and even with the bulbs in the link above, you will have to play around with the cover once you get the bulbs in. I recommend using a pair of small flat head screw drivers as there are minor latches on the side that need to 'snap' into place. If you do not get them to snap in, risk water getting in and destroying the socket. Its worth the pain, looks AMAZING when done!
Cheers!
Cheers!
Thank you for the link. It appears they are out of stock =(
In regards to the "snap". Do you mean the little latch that you have to unlatch first to open the cover? After you put the cover on, I had to use a screwdriver to push the latch in. Is there another clip or latch I should check to be sure the covers are properly in place?
Second, I am waiting for a reply from iJDM so they could hopefully send a replacement bulb set. (There website too needs to be updated and have the GLK350 removed from the list of compatible vehicles for the license plate bulb).
I will post pics of my progress.
BTW, for the H7 lowbeams, I am not planning to install HIDs as I do not want to drill the cap. I am hoping that by replacing the eyelids and DRLs up front with LEDs and replacing the lowbeams with H7 GE nighthawk platinums....it would give the car a great look without the need to go HID.
What do you think?
What do you think?
Wayne
http://www.youtube.com/watch?v=-F4ooqoEyf8
However, I went another route in opening the front dome light.
https://mbworld.org/forums/3580533-post48.html
I also used AZN Optics' leds for the park light and sidemarkers. Mike's 5000K led matches well with a 6000K HID.
For all other bulbs including the license plate light I used a 1 inch LED from a prior W204 group buy (Maxlux).
Does anybody know how to replace the map light bulbs under the rearview mirror?
Please guys, what do you think? Is this a major problem , or no biggy? Anyone else break a clip on these parking lights? Will they hold or fall out over time? Please, I am so worried.
