Anyone replace the gas and brake pedal with AMG
2013 cls550 & 2014 E550
Just wasnted to see if the Metal and rubber AMG style pedels fit the GLK and has anyone one this on the GLK and how hard was it to do? If not these what has anyone else used?
Location: VanCity (but in the 'burbs of the tri-cities)
GLK 350
According to the brochure, the metal/rubber AMG pedals come as an option in the Euro-GLK so they should fit. Not sure about the actual installation process however.
GLK 350
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
https://mbworld.org/forums/glk-class...ml#post4045672
I did a post on this a while back, i wanted the foot rest too so I went 3rd party.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
if you order one for W204(c class) or W212(e class), it will fit in our glk
i just installed one in my glk
installation is just straight forward replacement
for the gas pedal, unbolt 2 nuts then unplug the plug
then drop the new one
Mercedes AMG Pedal Set W212 E Class W207 E Class Auto
i ordered this one
it is very slightly different but it just sit right in
size is exactly same
new gas pedal has no little tab that the original has and it slides into the floor
and AMG pedal has click effect when you press it all the way
i think it is for full throttle or something
everything worked fine for me
but i know it is little pricy![smash](https://mbworld.org/forums/images/smilies/smashfreak.gif)
good luck
i ordered this one
good luck
2013 E550 Coupe
Hey, do have any pictures of your GLK w/ the pedals installed. I've made contact with Chet from your link post below. I just want to see it installed before I send the money... The other pedals look too bootleg/knock-off'ish, like the pedal covers you get at AutoZone or Pepboys...
i ordered this one
good luck
i ordered this one
good luck
