panorama roof
NA
panorama roof
How far is the sunroof suppose to open ? Today is the first time I open my 2012 GLK sunroof, but the glass stop about 4 inches from the edge of the front opening...![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Is it suppose to open all the way for the front opening ? Also how high is it suppose to tilt open ? (it only tilt up about 1 inch ??)![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
Thank you for any help !!
2015 VW GTI.S4; 2016 Audi Q3 Prestige
I do know that when you push the sunroof button back - it should be with some helf in your fingers for both the sunshade & then the sunroof to move.
I was quite surprised the first time I did it, it didn't do anything & had to add some ooomp to my push.
Red GLK350, blue '87 Toyota Land Cruiser
In my 2011 the button is the same as the side windows. Push it a little and the window stops if you let the button go, push it further and it moves all the way automatically. It only opens up far enough to clear the roof.
2004 Volvo XC70; 2012 GLK 350 4matic
I am equally sure that the manual explains all of the functions. If you follow the instructions and it still only partially opens, go see your dealer.
Wayne
Wayne
Stanley doesn't lie. Here is the real deal.
The full opening for sunlight and wind is 13 1/2" front to rear. Measured from the leading edge of the opening in the roof to the front edge of of the glass. Clear as mud? Measure for yourself. The tilt up open is maybe an inch. I can stick my fingers through with wiggle room.
Wayne
Wayne
2010 GLK 220CDI 4M BlueEFFICIENCY
Note 2012 GLK Operator's Manual, page #87: http://www.mbusa.com/vcm/MB/DigitalA...-GLK-Class.pdf.
I knew I had seen it: When the car's battery has been disconnected (or 12V power supply in any other way -), three items has to be reset - among them the "Panorama roof with power tilt/sliding panel".
Note page #260 of the manual referred to.
Actually, the 4" that they are talking about is the part of the sliding glass panel visible from inside the car when the panel is fully opened. Measure the opening from front to rear and I will tell you if it is correct.
Wayne
Wayne
