Brake Dust Fix
Nissan GT-R BE / '12 Ducati-1199 Panigale S / '12 C300-4M Loaded/GLK350-4M Loaded
Brake Dust Fix
Here check out THESE LINKS: https://mbworld.org/forums/c-class-w...ike-crazy.html & https://mbworld.org/forums/c-class-c...250-coupe.html
The majority consensus is.... Switch out your pads for AKEBONO/EURO Ultra-Premium Brake Pads... It's clear that even MB is playing around with different pads and materials to solve this complaint.
![](http://www.akebonobrakes.com/oem/images/oe_header.jpg)
![](http://www.akebonobrakes.com/aftermarket/euro/images/euro-actbullets.jpg)
Akebono EURO Ultra-Premium Brake Pads Link: http://www.akebonobrakes.com/afterma...uro/index.html
EURO Ultra-Premium brake pads provide the ideal vehicle control and response performance intended by the manufacturers of European makes.
The Akebono EURO Ultra-Premium brake pad line addresses performance specific requirements of European makes, providing vehicle control and response as the vehicle manufacturer had intended. These brake pads are formulated and fit with a precision that is remarkable sensitive to every application. This provides superb function and rotor compatibility, resulting in longer rotor life.
The use of highly advanced ceramic brake pad technology allows Akebono’s “EURO” pad line to provide excellent stopping power while extending rotor life and virtually eliminating brake dust.
Increased stopping power in critical braking situations
Improved pad wear performance over conventional disc pads
Reduced rotor wear by as much as 80 percent
Unrivaled in initial effectiveness with no break-in required
Ultra-quiet, positive, smooth braking performance
High resistance to fade with fast recovery
More consistent pedal feel
Rotor-friendly pad formulations
Enhanced durability and life
Low dusting and precision fit
Akebono’s Aftermarket disc pads contain the same materials, engineering, quality standards, and advanced technologies used to create their OE ceramic brake pads.
Warranty Information: 12 month - 12,000 mile limited warranty.
EURO Ceramic w/Shims
Material: Ceramic
Series: Akebono Euro
Quantity Sold: 2-wheel set
Warranty: 12-month or 12,000-mile Akebono limited warranty
Material: Ceramic
Anyone tried them yet?
Did you try these pads yourself, MBRedux?
I've tried to look for these but can't seem to find anywhere in Canada.
Anyone else have such luck?
