dust-free 'akebono ceramic' brake pads for the c250 coupe...?
Old May 15, 2012 | 11:11 PM
andrew e coupe's Avatar
2017 E400 Coupe & 2018 GLC43
Question dust-free 'akebono ceramic' brake pads for the c250 coupe...?
can anyone confirm the part numbers for the euro ceramic 'akebono' pads front & rear?
has anyone added them to their c250?
are the pads shared with any other c class to cross reference?
thanks in advance!
Old May 15, 2012 | 11:20 PM
... and are the c350 pads the same as the c250 front & rear for the coupe & sedan?
Old May 16, 2012 | 08:24 AM
AV1's Avatar
AV1
C204 C250-CDI
Interesting topic, I wouldn't mind a set of high performance low dust residue brakes pads for my vehicles
Did a brief research run on their main site and it appears they don't have them for our current 2012 C Class.
They only list W203 and S203 C Class sedan and wagon - 2005 onwards.
Unless there's other info maybe they've yet to make them for the W204 / C204
When I have time, I'll make a call to the Aust. and N.Z supplier to confirm
Old May 16, 2012 | 08:38 AM
Sportstick's Avatar
Another round of ICE
Akebono EUR 1340 and 1341 are the proper part numbers for a W204 C300. I've had them on my sedan for over a year with outstanding results. I do not know if the same part numbers apply to the coupe, or other powertrain variants, such as the C250.
Old May 16, 2012 | 11:10 PM
AV1's Avatar
AV1
C204 C250-CDI
Interesting those numbers are not listed on the Aust. / N.Z site.
I'll confirm what we (Aust.) can get when I get the chance to contact them
I'm sure they'll have those on inventory from Europe or elsewhere, just need to find out if and what suites our C250's also with and without the AMG package option if that makes any differences at all.
Old May 16, 2012 | 11:50 PM
I will contact my friend who is the Mercedes parts manager to see if he can cross reference some mb part numbers regarding pads.
Old May 17, 2012 | 04:43 AM
jctevere's Avatar
2012 C250 Coupe
There definitely are Akebono brakes for the W204 C300 and C350. I know that the C350 uses a different size brake pad for one (front or rear, not sure) but the other is the same.
The C250 brakes look about the same as the C300 brake pads, but you won't know for sure until someone tries to fit them on. I actually have a set of akebono brake pads up on my shelf in the garage, front and back. Maybe i'll check it out.
Old May 17, 2012 | 06:30 AM
~ i have confirmed the fronts are different part numbers from the C250 to the C350... perhaps the rears are the same?
Old May 17, 2012 | 09:19 AM
Sportstick's Avatar
Once you confirm the proper part numbers, FYI, I've bought sets for four of our cars on Amazon. I believe they ship internationally....
Old May 17, 2012 | 10:36 AM
~ update...
i have confirmed via mb... the rear brake pads are the same part number for the C250 & C350 coupe.
i will be ordering the rear akebono ceramic pads (for many now say the rears produce more dust than the front)... and await a part number or development of the front pads.
Old May 17, 2012 | 12:00 PM
~ these are the akebono ceramic rear brake pads i ordered for the c coupe:
REAR
EURO ULTRA PREMIUM CERAMIC PAD
EUR1341
Disc Brake Pad
Includes electronic wear sensor.
according to my search... the best pricing can be found here:
http://www.ebay.com/itm/Akebono-EUR1...6e7b59&vxp=mtr
Old May 17, 2012 | 02:58 PM
Showa's Avatar
99' Lexus RX300-retired, 01' BMW 330i
So there are 2 brake sensors for both rear brake? Let us know how it response comparing with the oem brake pad. Thanks.
Old May 17, 2012 | 03:05 PM
Sportstick's Avatar
Lots of experience on the W204 sedan side...good initial bite, very solid feel, no noise, and best of all, essentially no dust. I've not had to use wheel cleaner since putting in Akebono EUR pads...just regular washing along with the rest of the car. (different cloth, of course!)
Old May 17, 2012 | 03:33 PM
~ should only have one sensor per axle (looks like a cut & paste pic) ... i will most likely simply re-use the oem sensor as normal.
Old May 17, 2012 | 04:22 PM
DameMD's Avatar
X3 M40i
Good find!!! I hate the way the rear brakes dust so easily. I hate having to wipe my wheels off after each drive.
I will definitely get a set soon.
Old May 17, 2012 | 06:18 PM
jctevere's Avatar
2012 C250 Coupe
Yeah, all three models use the same rear brake pad, C250, C350 and C300. If I am not mistaken, I also think that only the C350 has a different (bigger) front brake pad. That means that the C250 and C300 should be the same... Once I get home I will look at the other Akebono part number I have for the pads on my old C300 sedan.
Also, there is only on brake wear sensor for the front and back respectively (meaning two total).
You can re-use the brake pad sensors if they have not been worn or triggered yet. However, if you run into any problems, its probably best to just get an extra sensor or two as they are relatively cheap ~$5-$10.
Old Jun 1, 2012 | 10:07 AM
Thumbs up
~ i found front ceramic pads as well C250... (only supplier)...
i just ordered them.
http://www.rockauto.com/catalog/raframecatalog.php
2012 MERCEDES-BENZ C250 1.8L L4 Turbocharged: Brake/Wheel Hub: Brake Pad
Price Alternate RAYBESTOS Part # PGD1340C Professional Grade Contains Electronic Wear Sensor
Ceramic; OE Pad Material is Ceramic; Front
$40.79
Old Jun 3, 2012 | 12:27 PM
install complete (front & rear):
fronts:
rears:
difference between dusty oem & ceramic (lighter) pads:
fronts:
rears:
~ also... red color on pads will dry clear... this is an anti-squeal product.
Old Mar 28, 2015 | 08:41 AM
Looks like I be buying these for my new E400 coupe as well. Great dust free pads.
Old Mar 29, 2015 | 10:57 PM
AV1's Avatar
AV1
C204 C250-CDI
Hey Andrew talk about reviving an old thread
You now have an E400 coupe - Congrats !!!
My next move will be one of the new upcoming C205 C63S AMG coupe
On the subject of the Akebono pads, I've been running them on my C204 for the last year and can only say all good about them - definitely better than original OEM overall and virtually dust free.
I would recommend them to anybody
Old Apr 8, 2015 | 06:24 PM
~ yeppers... thanks!
i have completed a few upgrades to the new e400 4-matic coupe so far...
~ full clear bra
~ full 50% window tint
~ gloss black painted grill
~ dust free brake pads
~ de-badged
~ winter mats
~ trunk liner
~ lowering springs
awaiting the install of the 19" from the c coupe (the 18" amg are undersized for this car)... more pics to follow.
dust-free 'akebono ceramic' brake pads for the c250 coupe...?-e-20coupe-20rear-20side-202_zpsbfwnvm3o.jpg
dust-free 'akebono ceramic' brake pads for the c250 coupe...?-e-20coupe-20rear-20side-201_zps8nzulsf0.jpg
dust-free 'akebono ceramic' brake pads for the c250 coupe...?-e-20coupe-20front-20side_zpsqo9xpwcc.jpg
dust-free 'akebono ceramic' brake pads for the c250 coupe...?-image2_zpspwzkgc8r.jpg
dust-free 'akebono ceramic' brake pads for the c250 coupe...?-grill2_zpsfcumrirx.jpg
Old Apr 9, 2015 | 11:11 PM
AV1's Avatar
AV1
C204 C250-CDI
Very, very nice Andrew !!!
Congrats and well done once again, enjoy the ongoing Merc experience their cars are just getting better and better
Was all set on a very long term ownership of my C204 but after seeing the end result of the new W205 AMG's which are so much better than the 204 series AMG's I can't wait to see what the new C205 AMG's have to offer, if they're going to be as good as rumoured and certainly what they're shaping up to so far I don't think I'll be able to resist the urge to update sooner rather than later.
Look forward to more pics of your E400 - paste a link for us if it's located in the E Class forum section
Old Sep 13, 2015 | 05:19 PM
Lowflyer's Avatar
2012 C250 Coupe, 2017 C43 AMG Coupe
~ full clear bra
~ de-badged
~ winter mats
~ trunk liner
~ lowering springs
First off, not cool posting pics of your e coupe under thread meant for the C Class! Why?.....I'll tell ya why, It makes it extremely hard for members such as myself to ever look at their C204 and still love it as much. Suddenly extra debt seems acceptable....Lol! Your car is absolutely gorgeous, we obviously have great taste considering we have identical C204's.....anyways, I do have a reason for my post, did you go with Eibachs again on the e class?
Old Sep 14, 2015 | 09:13 AM
Talking
~ I had to go with Vogtland lowering springs for they were the only company producing a set for the awd version. I must say they are perfect and seem identical performance and ride wise to eibach and h&r sport springs.
some updated pics of the e with the staggered 19"...
dust-free 'akebono ceramic' brake pads for the c250 coupe...?-wheels-20front_zps2643gpdm.jpg
dust-free 'akebono ceramic' brake pads for the c250 coupe...?-wheels-20front1_zpsgsxrkp1e.jpg
dust-free 'akebono ceramic' brake pads for the c250 coupe...?-wheels-20drive-20rear_zpsuiarosje.jpg
Loving it so far...
Added some subtle mods of course... full clear bra, lowering springs, 50% window tint on all windows, debadged, 19" wheels, painted grill gloss black, etc...
Old Jul 3, 2017 | 02:26 PM
DarkSpark's Avatar
2012 C 350 Sport Coupe _ 2012 GLK 350
Put a set on immediately if not sooner! They are awesome brakes with almost NO brake dust. Ive had the fronts on my 08 W204 since last summer July 2016 and the response was incredible, so I went with the rear as well, it feels like a completely different car. You will have to learn to re-adjust your brake pedal pressure as the amount youre used to applying will make you and your passengers pitch forward somewhat in the seats. All things equal, lighter, gentler pressure will stop the car from what you got used to. This doesnt stop over time so Ive kinda ruled out that it was simply from having more pad material. I concur with the findings and experience of fellow listers AV1 and Sportstick, they are really good brakes with little to no dust, wash the car, and a quick and I mean quick wipedown and your wheels look like new.
