Installed storage bins
Old Jul 7, 2012 | 07:35 PM
JohnMichael's Avatar
2012 GLK 4Matic, 1999 S600, 1994 E320 Cabriolet
I take a lot of road trips and needed more storage so installed the under the front seat storage bins today. I thought I would have to remove seats to attach them with rivets but instead used socket head screws and screwed right into the existing seat frame holes. I had enough access but had to enlarge the two bottom holes in the bin slightly. Overall a pretty easy job and took less than an hour. They are standard equipment on all the 2012 GLK's sold in Canada.
Old Jul 7, 2012 | 11:55 PM
Jlazer's Avatar
Mercedes-Benz GLK 350
Show somes pics , sounds like a good idea
Old Jul 8, 2012 | 01:00 AM
Bin pictures
These are not huge but do provide a good place for smaller things like sun glasses case, flashlight, maps, collapsible umbrella etc. Holes are already there in the seat and are factory installed with rivets but I couldn't get enough clearance to fit a rivet gun under the seat so used screws.
Attached Thumbnails Installed storage bins-bin.jpg   Installed storage bins-bin-open.jpg
Old Jul 8, 2012 | 03:26 AM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
hey how much did the parts department charged you for those sets (in canadian funds please)? did you just used screws from Home Depot or Rona? what is the exact size that you used? thanks!
Old Apr 14, 2014 | 10:44 AM
koalatm's Avatar
2016 Golf R, 2014 GLK
Is anyone aware of how to *remove* these? My wife and I absolutely hate them. They make the seats squeak and they take up leg room.
I'd be more than happy to give them to a fellow GLK owner if we can safely remove them. I wasn't sure as they do look riveted in place.
Old Apr 14, 2014 | 11:08 AM
Bob338's Avatar
'85 190D , '12 E350 BlueTec, '13 GLK 250 BlueTec
There's 4 screws at the very back, two going up that are a ***** to get to, and two that are visible when you open the compartment and look in the back up high.
There's no way they can cause the seat to squeak. They are attached to the seat frame below the seat. In my color they did not provide them and it was not an option when I ordered mine. I've since ordered and installed. I sure would have taken your kind offer had you posted a couple of months ago. With a discount I paid $300 for mine. Easy to install and easy to remove, they were just not available in Palomino. I bought black and you can't even see them, but they sure provide the space for little miscellaneous things. A very worthwhile addition which I would have ordered had it been a factory option at the time. Had them in my E class as standard equipment and I really liked them.
Old Apr 14, 2014 | 11:10 AM
koalatm's Avatar
Thanks for your reply. The reason they make the seats squeak is that the outside edge of each seat tends to rub against the top corner of the storage box. I think I can fix this with a bit of felt or something - but it still doesn't fix my lack of leg room
Old Apr 14, 2014 | 11:17 AM
Bob338's Avatar
Spray some silicone spray on the place of contact. Or, better, loosen the 4 screws and slide the units inboard a bit. Still not sure how they contact as mine don't, but the spray should take care of the squeak. Or wipe some Armor-all at the contact point.
Old Apr 14, 2014 | 11:20 AM
koalatm's Avatar
I'll definitely see if I can adjust them first, but it looked like the two rivets from the factory might prevent them from being moved forward or back.
Old Apr 14, 2014 | 10:57 PM
GLK350AMG's Avatar
2013 GLK350 4-Matic & 2003 E320
I'm actually surprised my 2013 doesn't come with storage bins. koalatm, if you decide you don't want them, can I take them off your hands? I'm back in Canada in a few months.
Old Apr 15, 2014 | 11:52 AM
koalatm's Avatar
If I can find a safe way to remove them! But it looks like they're permanently riveted in place.
Old Apr 15, 2014 | 11:59 AM
Bob338's Avatar
That's strange because the parts book definitely shows screws, and in fact with that part number I was able to buy them locally after I bought the bins, which came in from Germany.
If they are indeed riveted, I'm certain that would have to be before the seats are installed as two or the screws, or rivets, would be vertical and there would be no way to drill them out without removing the seats. Yet it would be quite strange for the parts books to show screws instead of rivets.
Old Apr 15, 2014 | 04:31 PM
mjhawkins2346's Avatar
2016 GLE300d 4Matic
Sounds interesting. Can you share parts numbers or the retailer you used for this purchase?
Might be worth doing.
Old Apr 15, 2014 | 07:20 PM
Bob338's Avatar
http://www.oediscountparts.com/parts...iagram=5900390
You can find the parts number there somewhere. They gave me excellent service and I'd use them again in a heartbeat. Guy called and pointed out my car didn't have them to start and wanted to verify color. "I know!" He wanted to make sure I got what I wanted. I think the part number is in there somewhere. It changes for color. I ordered black to make it less visible. I carry something there I don't want folks to look at or be able to obviously see. In black in my car they're practically invisible.
Old Apr 17, 2014 | 07:31 AM
miked807's Avatar
GLK250 BlueTec- 2014
.......... I carry something there I don't want folks to look at or be able to obviously see. In black in my car they're practically invisible.
Hi Bob;
thanks for the that link and part#'s ....
So is that TRY big enough to carry like a LAPTOP ?
am sure an IPAD AIR would fit there right?
I am looking at fitting the Passenger Side ONLY - do you see any issues with that being ONE SIDE only? would it look odd?
Old Apr 17, 2014 | 07:42 AM
Bob338's Avatar
Originally Posted by miked807
Hi Bob;
In black the bin is very much hidden. I never see them. They are not very deep and no, they won't fit a laptop. Haven't measured but I'd guess something less than 5" wide is max. Have no clue as to size of iPad as I don't have one.
Old Apr 17, 2014 | 03:05 PM
rmfnla's Avatar
2013 Infiniti G37 Coupe; 2011 GLK 350 w/ Premium 1, Multimedia & Sport Appearance; I LOVE IT!
No such thing as permanently riveted; all you need is an air hammer with a chisel...
Old Apr 17, 2014 | 05:38 PM
Bob338's Avatar
A small punch, smaller than the rivet diameter, and a big hammer will also do!
Old Apr 18, 2014 | 04:17 PM
rmfnla's Avatar
Assuming there's room to swing a hammer...
Old Apr 18, 2014 | 05:39 PM
Bob338's Avatar
There isn't! Seats have to come out whether drilling or punching!
Old Apr 21, 2014 | 12:48 PM
rmfnla's Avatar
Air hammer and chisel will shear off the rivet head from the side; no need to remove the seats...
Old Jul 14, 2015 | 11:18 AM
ebyskov's Avatar
Mercedes B -200 W246
Some help needed to remove the seats before installing storage bins
I have a B-Model 200 from 2013, and I have just received 2 storage bins, 2 hold rails and some 12 fitting screws.
Can somebody tell me how to remove the seats, and do I need to make extra care to cables to the seat for 'air-bags' ?
A direction to some hints, Pictures or exploded drawings is very much appreciated.
Old Jul 16, 2015 | 09:23 PM
You need to remove the negative terminal from the battery first before unplugging any of the harness below the seat. You do not want to trigger a airbag malfunction which you can only remove by going to a dealer. There are 4 bolts holding the seat, one at each corner, use a correct torq socket to remove the bolts.
Old Apr 17, 2017 | 11:50 PM
Mstasglk250's Avatar
Glk 250
Removing under seat storage glk
I used a Dremel to remove the front rivets. Here's a link to the process end to end.
Old Apr 18, 2017 | 01:19 PM
AzCamel's Avatar
10 GLK350/ 15 Accord/ 94 Supra Turbo
I'm in arizona and will buy them if anyone of you guys removed them and they are in good condition
