Taking my 2013 "2 weeks old/450 miles on it " GLK for service already
Having an issue with the front right wheel - the brakes are causing excessive wear on the disc. I can tell just by the way the disc feels, and all the brake dust it's giving off. Every other wheel disc is completely smooth, and pretty much no brake dust.
Also, I have some clearish liquid leaking from just about where the windshield starts, under the car. It doesn't smell like anything, and has the consistency of water, so I assume it's that dam washer fluid/reservoir thing I keep hearing about.
Third...slight wind noises from the drivers side area, and a few creaks from the dash now and then.
It was also pulling to the right, but got that fixed during a detail job.
All in all, I'm pretty happy, especially when the car is spotless! BUT, I really don't like the aspect of visiting the dealership so soon after driving off the lot.
GLK350, G55, AMG GTS, C63 507
Sorry to hear that, I can only relate to the wiper leak cause my GLK had a problem with that also since the first days I got it. Check this out https://mbworld.org/forums/glk-class...e-1-month.html
Do you run the AC. If so you will get a puddle of condensate water under the car behind the passenger front wheel I think. It is from the condensate drain for the AC.
I thought about the condensation from the A/C, but I don't think it's that. I noticed some leakage right after pulling out of the garage, first thing in the morning. It had been sitting in the garage overnight (off for at least 12 or so hours).
I don't think it would be dripping all night. However, it really does almost look like water, so I'm not sure what to think.
The dripping is happening about where the driver and passenger seats are, so a little bit deeper than the windshield actually. Updates in a few days, taking it in tomorrow.
The washer fluid leaking was a problem since 2010. I was surprised that until now this issue was never been corrected. MB better listen to us or else there are alot of competition out there.
2013 GLK350 4Matic, 2011 BMW 535i, 2012 Nissan Frontier CC SV
Our 2013 GLK350 had the exact same problem with the front left wheel. It had about 30 times more brake dust than other wheels. The brake feel was weird. Took it in. Dealer said it is normal for MB vehicles that the 4 brakes do not have even brake wear. He also said that we continue to drive about 500 miles and the problem will be gone. Even though they didn't acknowledge any problem, I know they adjusted the front left brake a little bit. The weird brake feel was gone afterwards. But the front left wheel still has way more dust than other wheels. Let's see what happens after 500 more miles.
1 Post
2012 GLK 350 P1 COMAND LIGHTING AMG... , 2011 maxima
I have the same problem with 2012 ... the front left wheel has so much more dust have about 12k miles now. still have the problem. let me know what happened at the dealer .. you think it's worth the trip to the dealer?
![Stick Out Tongue](https://mbworld.org/forums/images/smilies/tongue.gif)
So in short, don't let the dealer wash your car unless you don't mind scratches everywhere.
Oh man. I have brake dust like no other on the front wheels. I was surprised how much it is an wonder if I should take it in for that. I am actually have some other problems with the car that it needs to go to the dealer but as I don't want to thread jack I will save those for some other thread.
Oh well.....dealer says brakes are functioning 'perfectly'. The drip IS from the ac. They said the clicking is from the ac adjusting internal vents (which I still think it's from the way the dash is assembled - I can put pressure on the wood and hear similar creaks and clicky sounds). AND, when the window was tinted, a flap was tucked weird, so they straightened that out.
Oh, car wash too.
Oh, car wash too.
I drive pretty easy actually. My spirited days are over (I'm 38, but definitely drove spirited in my early twenties
I only accelerate for fun, but my braking is always light/normal. I guess I'll just carry a wheel polish rag around with me.
Believe it or not I actually hardly ever use cruise control, in any vehicle I've owned.
I didn't want to accuse anybody, just thought I state a fact which a lot of people are not aware of.
btw: 38 years of age. still young enought to do spirited driving
Bedding in new brake (pads) and tires
There is a venerable procedure for bedding in new brake pads and/or new tires (in a new car or when you change them at service) over the first 500 miles or so. That being said I take no responsibility for any failure or accident so you may want to check with your dealer first.
Make sure all of your tires are at the recommended pressure. Drive the car until all the fluids warm up. Then, as I recall, one varies the speed of the car and pumps the brakes periodically. Vary the force with which you pump the brakes. For example, a few "stand on it" going from 65 down to 20 mph where safe only! is recommended during this period. For safety sake, at higher speeds, of course one needs to do this on an open highway with minimal traffic but one can also do it at slower relative speeds around town while stopping at a light and so on. Alternate this pumping with a "steady pressure on the brake pedal stop" mimicking the highway stop as is safe.
While bedding in the pads you are also getting rid of the mold release that is on the new tires and makes them feel a bit "greasy." In my experience this works well to get your brakes and tires well broken in and working the way they should. A side benefit is it will get the driver used to the characteristics of the car.
Last edited by grane; 10-23-2012 at 09:15 AM. Reason: Information given to me by comp. driver
Make sure all of your tires are at the recommended pressure. Drive the car until all the fluids warm up. Then, as I recall, one varies the speed of the car and pumps the brakes periodically. Vary the force with which you pump the brakes. For safety sake, at higher speeds, of course one needs to do this on an open highway with minimal traffic but one can also do it around town while stopping at a light and so on. Alternate this pumping with a "steady pressure on the brake pedal stop" as is safe.
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
