2013 - Wheres my fog light button??
Old Dec 1, 2012 | 09:31 PM
Tugz2012's Avatar
2018 AMG GTC Roadster, 2017 GLS450
I have picked up my 2013 GLK and I have the Xenon Lighting package with Adaptive High Beam Assist. My GLK has front fog lights, but I have no idea where the switch is. When I look in the manual, it should be beside the rear fog light switch. I only have the rear fog light switch. How do I turn my fogs on??
Old Dec 1, 2012 | 10:18 PM
venchka's Avatar
2004 Volvo XC70; 2012 GLK 350 4matic
Describe your front fog lights. Start you GLK in the daytime. Set the light switch to AUTO. Walk to the front and tell us what lights you see.
Are you in Canada? If so, I was never here.
Wayne
Old Dec 1, 2012 | 10:27 PM
venchka's Avatar
I just looked at the photo in your other thread. You don't have front fog lights. You have LED daytime running lights. Just like my 2012 with the Premium Light Package.
Set the light switch to AUTO and fuhgettaboutit.
Wayne
Old Dec 2, 2012 | 08:52 AM
GLKKa2H's Avatar
2010 GLK 220CDI 4M BlueEFFICIENCY
Originally Posted by Tugz2012
- How do I turn my fogs on??
The Daytime Running Lamps (DRLs) may not be "programmed" to be lit, if so, they must be switched on by using the on-board computer.
Old Dec 2, 2012 | 05:47 PM
venchka's Avatar
Thanks for the reminder. That is the DRL on switch. Set by our dealer at delivery and not touched since. I will never understand the US allowing an essential safety feature to be user defeated.
Wayne
Old Dec 3, 2012 | 08:24 AM
venchka's Avatar
I suggest that you read the book.
Page 33, #5 in the illustration.
Page 217. Overview of the menu system.
Page 227. Activating DRL. Also see page 111.
Set the main light switch to AUTO. You will never be in the dark. Others will be able to see you.
Good luck.
Wayne
Old Dec 3, 2012 | 08:42 AM
bop11's Avatar
350 GLK, C280
Does this mean that 2013 and newer will not have factory fog lights? Do the LED's put out a wide, low light field? I use the fogs a lot at night running through backwoods roads to light up the sides so I can see the critters that want to take out my front fenders. I also use them in rain and fog to see the Jersey Barriers. If I didn't have them, I think I would put on aftermarket fogs. Funny, this comes up now as for the last 5 days we have had heavy fog in the Delaware Valley area.
Old Dec 3, 2012 | 09:27 AM
venchka's Avatar
I miss fog lights on our 2012. The LEDs replace the fog lights with the Xenon light package. However, I would gladly give up fog lights for the Xenons. It's dumb not to have both. Alas, LEDs are in fashion. Fashion before function is an alien concept to me.
Wayne
Old Dec 11, 2012 | 10:06 AM
venchka's Avatar
Another Hit & Run.
Wayne
Old Dec 18, 2012 | 11:59 AM
aamirani's Avatar
2011 C300 4MATIC
Calm down Venchka. It's a forum. You're acting like a child.
Posted from Mbworld.org App for Android
Old Dec 18, 2012 | 12:11 PM
venchka's Avatar
Curmudgeon would be more like it. Point taken.
Common courtesy does go a long way to ensure help at Forums like this.
Wayne
Old Dec 18, 2012 | 10:57 PM
dcjwlee's Avatar
2013 GLK 350 4M (Iridium Silver), 2010 E350 Coupe (Iridium Silver)
Unfortunately, with the lighting package you receive CORNER ILLUMINATING LIGHTS (they may or may not call them fog lights in the brochure). They are integrated into the main headlamp housing and only turn on when you are turning left or right under a set speed or turn on your turn signal while travelling under a predetermined speed.
Alas, in my 2013 without lighting package the LED DRL is standard. Not particularly pretty to look at and completely useless considering they could have simply used the high beams as a DRL and left the much more useful fog lights alone.
Old Dec 19, 2012 | 09:36 AM
grane's Avatar
GLK350, SL63 AMG
If you notice the LED strips on the standard US 2013 package are angled so that they act as fog lamps. I'll have to ask my wife if it is "always on" in the auto position and increases illumination at night. We are in critter happy environs so we have to have "side road" illumination.
The reason fog lamps perse were removed because of a nanny EU study that said 3 % of other drivers found fog lights were distracting. If anything is misused or misaimed it will cause problems.
They went to a LED array rather than a fog light; same effect with "a light that dares not speak its name."
Old Dec 19, 2012 | 06:01 PM
dcjwlee's Avatar
Thumbs down
Swinggggg....
And a miss.
