Tell me 3 things that you DON'T like about your GLK250
Old Jan 7, 2014 | 02:23 PM
  #51
rmeier1's Avatar
GLK 250
EVTee,
It's not a burnt smell, it's the smell of raw diesel fuel. I thought it might be from a
weeping injector line or a tank vapor recycling line. Will get it checked at first service.
Old Jan 7, 2014 | 02:30 PM
  #52
rmeier1's Avatar
GLK 250
mike-nc
Looked again for an aux jack in the center console. Nuthin but a blank filler piece next
to the USB jack. Mine is a '14 GLK, U.S. spec., std. audio, made in mid August.
Old Jan 7, 2014 | 07:29 PM
  #53
107123210's Avatar
Originally Posted by rmeier1
mike-nc
If you have the standard Audio 20, then all you get is a USB port in the center console. You can plug in a memory stick and play tunes. That is also what I have. Works great, especially if you arrange the music by album, genre or whatever you want. Audio 20 probably allows you do as much as you could do with an iPod or MP3 player, without having to touch the device.
Old Jan 8, 2014 | 03:42 AM
  #54
EVTee's Avatar
2010 BMW 335d, 2013 GLK250
EVTee,
My apologies. Yes, diesel fuel smell is definitely not good.
Old Jan 8, 2014 | 06:25 AM
  #55
mike-nc's Avatar
2013 GLK250BT
mike-nc
Must be one of those things that got deleted for 2014. I use a flash drive in the USB port for music.
Old Jan 8, 2014 | 11:46 PM
  #56
emtskibum's Avatar
2014 GLK 250
Anybody else notice a steep decline in MPG in cold <freezing temps in their 250?
Old Jan 9, 2014 | 12:09 AM
  #57
glayfan40's Avatar
2010 911 Turbo Cabriolet, 2014 Mazda3
Wouldn't necessarily call it steep but yes it's about a 10% avg drop for me as compared to the summer months. I've been getting 27-28mpg in the last 3 months instead of 30-31mpg.
But that is to be expected given the winter blend fuel content differences. Same thing applies to gassers as well, probably more so than diesels (based on my observations made on previous cars).
Old Jan 9, 2014 | 08:47 AM
  #58
fcch's Avatar
SLK 350 2013
Me as well. ... I was getting a solid 6.0 l/100km. (according to the dash reading).
It's been a solid -25 to - 18 celcius for a few weeks and I'm up to 7.0 - 7.2 instead. I found this as normal having had diesels before and the gassers did it too. I don't idle the vehicule for extended periods before leaving. Just the time to clear the frost and snow.
No problems with fuel since I started adding additives at every fill-up. Can't trust the service stations to have good -40 diesel.
Old Jan 9, 2014 | 09:42 AM
  #59
rmeier1's Avatar
GLK 250
True, and I use it too, but I miss being able to play my good old cassette media. These
recorded albums are better quality than MP-3 format. It's a pain to redo it all.
Old Aug 23, 2014 | 04:23 PM
  #60
rmeier1's Avatar
GLK 250
About my problem with the diesel smell...
I took the vehicle in for the A service and mentioned the problem. They found a
fuel line leak. They had to order the part, so after 10 days it's still in the shop.
At least I got a loaner GLK.
Old Oct 3, 2014 | 11:03 PM
  #61
ferreirabill's Avatar
2001 ML430, 2014 GLK250
1. Ground clearance, lack thereof
2. Command system
3. Crazy option packages
Old Oct 7, 2014 | 01:42 PM
  #62
drumminj's Avatar
'14 GLK250
Originally Posted by ferreirabill
2. Command system
Really? I actually find that I like the system, though I was skeptical about it when making my purchasing decision. I find it's easy to do/navigate to what I need. Not as many frills as what Audi offers, but I actually prefer that.
Old Oct 7, 2014 | 01:56 PM
  #63
Command system
Take something simple and make it complicated, the Command System.
Compare using the radio and our 2001 ML to our 2014 GLK, 5 times as much work to do the same thing. Admittedly not as bad as BMW's system but still...
We need a law in the United Nations to make it illegal (politically incorrect statement warning) for the Germans to design human software interfaces. Whether business software from SAP, various programs available for personal computers or car interfaces; they just haven't a clue.
And the navigation system interface, give me a break. Is there a worse one in existence (well yeah Google)?
Old Oct 7, 2014 | 02:37 PM
  #64
Mike_W's Avatar
2013 CLS550, 2013 GLK350 4-Matic
We have a gasoline 2013 GLK 350 4-matic, not a diesel - but these are generic
1. Awkward positioning of turn signal lever and cruise control. Too easy to turn CC on when using turn signals. The positions of the two levers are reversed from my 2008 E-class. (Not near as exciting as switching from my old Triumph T160 motorcycle to my newer BMW. The Triumph has the rear brake lever and shifter on the opposite sides as modern bikes)
2. Inability to input navigation destination via control knob while vehicle is in motion. I'm sure this is supposed to be a safety feature, but it also prevents the passenger from entering data. My E doesn't have this "feature" and yet I haven't crashed once.
3. Wind noise at freeway speeds - this was fixed by the dealer.
But, my wife loves her GLK and as they say - Happy wife, happy life
Old Oct 7, 2014 | 02:54 PM
  #65
Number 4
Number 4: $1,000 to change the oil and top up the DEF tank. My Camry was $150 for 3 synthetic services per year. Over a grand for one service at the MB dealer.
Old Oct 8, 2014 | 12:02 PM
  #66
bugelrex's Avatar
glk
There really is no reason NOT to do the DEF refill yourself for $10-15 unless you are so busy you can't spare 30 mins. I'm horrible with DIY, but just buying the special refill bottle and carefully cutting the cap allows you to refill yourself in 20 mins with zero spills. The only hard part is twisting/pulling the trunk cover off
Old Oct 8, 2014 | 03:46 PM
  #67
rmeier1's Avatar
GLK 250
Just so bugelrex! ferreirabill, you can refer to the threads about DEF replenishment to
see how easy it is. Less than $30 for 5 gallons from most auto stores vs $9 a liter from
Hans und Franz at MB.
Old Oct 8, 2014 | 04:52 PM
  #68
Admittedly this is not something I'd researched.
For the past 6 years, we've been paying our Toyota dealer $150/yr for up to 3 synthetic services per year. While I knew the MB dealer would be somewhat more expensive, I was floored when the dealer tried to sell us MB's service plan. Note that parts and labor are almost identical for both vehicles, people who come from Subaru to Toyota are shocked at the parts and labor prices there.
True the MB service also includes DEF so perhaps an extra $100 per service but an extra $1,000. That almost seems like larceny.
Note that the service at this MB dealer is the best I've experienced in 40 years of driving MBs, they've been taking excellent care of our 2001 ML430. I thought that $650 to change the 16 plugs a might high until I discovered the difficulty of performing the task myself and the special tools I'd need to buy/make. I'm not a novice at vehicle maintenance but have been enjoying not doing it since retiring. With this GLK, I'll be back to doing much of it myself.
So I'll use their service and pay them by task and not for a flat rate service. I don't need to pay them to glance at the brake and coolant fluid tanks.
Thanks for the tip about searching the forum on DEF maintenance, will also be searching for info on a service manual.
Bill
Old Oct 9, 2014 | 07:54 AM
  #69
bugelrex's Avatar
glk
A sane person might guess an extra $100 for DEF, but some dealers were charging $300 (4 years ago)!!!
http://www.thetruthaboutcars.com/201...ing-expensive/
Old Oct 9, 2014 | 06:31 PM
  #70
rmfnla's Avatar
2013 Infiniti G37 Coupe; 2011 GLK 350 w/ Premium 1, Multimedia & Sport Appearance; I LOVE IT!
Originally Posted by bigd69
Why do I have to hold the seat memory button until the seat moves into position? Never had to do this before, should be a push without a hold...I"m 6'7"and my wife is 5'6" so I have to stand outside of the vehicle and hold the button for nearly 20 seconds until the seat fully adjusts to my setting. Grrr.
Originally Posted by Bwadd
Never understood this.... It's the same on our c350!
Got stuck yesterday waiting for my seat to go back to my position in -25 weather with blowing snow... Not fun!
Originally Posted by bugelrex
Its a safety guard, if you are driving and accidently hit the wrong button, you dont want to get distracted while it moves all the way.
Originally Posted by glayfan40
They could've easily made it so that we'd have to push and hold for 3 seconds then the seat goes to position all the way.
My #1 complaint.
My Infiniti G37 only requires a single push, but better than that the seat position can be keyed to each fob, so when I unlock the car it adjusts itself to my position as I am opening the door.
#2 complaint is the 1950's technology light bulbs in all but the headlights. I have a 2011 and the Xenon package was not available on an in-stock car and I didn't want to wait for a special order. The cheapest Tototas and Hondas have had LEDs for years; WTF..?
#3 is the windshield wiper control at the end of the stalk; I frequently activate the wipers when flashing the highbeams.
Other than that, I love the car (and the cheapo door lock pins are easy to upgrade)...
Old Oct 10, 2014 | 01:20 PM
  #71
"The cheapest Tototas and Hondas have had LEDs for years"
Not true in the US, perhaps other countries. Some of the high end models have partial LED, same for the Hybrids but the cheapest models: nada.
After paying over $700 to replace the Xenon low beam bulbs on our ML430, we specifically bought a GLK without them. Next time they need replacing, I'll convert the system to Quartz Iodine.
I'm 6' and my wife 5' and I'm quite glad that the button has to be held. We live in CO so we know about standing in the cold, still better than being jammed against the controls if I accidentally bump the button while driving. And yes, I've done that.
Certainly agree that putting the cruise control next to the directional was stupid. The old design had them both at the upper quadrant, just as poor a design. Someone was taking stupid pills when they came up with this.
Old Oct 12, 2014 | 07:09 PM
  #72
Bob338's Avatar
'85 190D , '12 E350 BlueTec, '13 GLK 250 BlueTec
While at the factory I complained about the same thing. I was told the European Union passed a law specify that location on all cars manufactured there. That would mean Audi's, VW's, and all the others have them. I don't know that's the case but that's what I was told.
Old Oct 13, 2014 | 05:04 PM
  #73
rmfnla's Avatar
I've seen Corollas and other econoboxes with LEDs so they do exist.
Never thought about replacement cost of the Xenon bulbs; thanks for the silver lining on that cloud!
I've also never bumped my memory seat button so my preference would be one-push, but if the memory was tied to the fob it would be a moot point...
Old Oct 17, 2014 | 02:58 PM
  #74
oscaar12's Avatar
2015 GLK 250 o3 clk 430 09 c 300
1 The back up camera is too slow to start
2 If you leave the keys in the radio still goes
3 In Canada you can not change the outside weather temp from c to f
Other than that it kicks the crap out of a $75000 Yukon SLT in every way possible.
Old Mar 1, 2015 | 08:42 AM
  #75
kenzo_M's Avatar
glk250
1 - Black interior ... easy to get dirty during winter, should have op for Brown leather
2 - 9.0L /100km combined (December 19 until now, Toronto).. 600km per tank
3 - require more CARE ..:-)
just enjoy my new 2015 GLK250
You have already rated this thread Rating: Thread Rating: 1 votes, 4.00 average.
