Nitrogen refill for tyres?
Opinion, I've used it and have concluded its value is way overblown. I quit using it as it was easier to check my tires regularly and not worry about the increased pressure when they got hot. Besides it's able to get through the rubber much easier than compressed air and you have to check more frequently and adjust pressure loss from that.
If oxygen was able to "seep out" while nitrogen stayed in, then the tire would be a nitrogen sieve.
The nitrogen level would increase each time you added air to the tire and more o2 seeped out.
Pretty soon, only nitrogen would be left.
What I glean from much reading is one advantage of N is it is dry. If extra dry air was readily available for tyres then there is little difference. However not all air in our tyres is this quality. My conclusion is if you have paid for the nitrogen then continue to use it. If the dealership wants to charge me again with the new tyres, I will say no! Do new MB's have nitrogen in their tyres from the factory? What is the Euro view on this topic?
Funny story. In the 50's working at a remote gas site in the hills of Louisiana, a couple of guys who worked for me decided to go into town about 60 miles away. They noticed that their only car had a flat. So they fixed it, but not having an air compressor, filled it with natural gas. At the first gas station they came to, they told the young attendant to "Fill er up and change the air in the tires".
The kid thought they were joking, but they said "No, the air mixing with the rubber becomes explosive". To show him, they took a lighter held it near the tire valve and let a little gas out, resulting in a long jet of flame.
Convinced he proceeded to change the air in all four tires.
As they were leaving they heard the attendant ask the next guy, "ya all want me to change the air in your tires?"
Unless you are into racing on the track, where the thermal coefficient of N2 reduces the increase in pressure as heat builds, forget the N2.
Opps, I work for a major supplier of industrial N2, forget what I said.
