Suz133
Old Aug 25, 2013 | 10:22 AM
Suz133's Avatar
Glk
Suz133
I am very interested in purchasing a glk. But noticed during test drive that the sun roof doesn't
have a solid cover to block out the light and heat, it only has the mesh cover. Does that offer any protection from the uv rays?
Also, in the summer time do you find the car is warmer inside since the roof doesn't completely block out sun...especially if you have black on black interior
Old Aug 25, 2013 | 05:04 PM
Atoche's Avatar
2013 GLK 350
I find with the mesh shade closed, and using a sun visor - the car remains cooler inside (even with the panoramic roof) than it would be if i left the mesh shade open and did not use a sunshade.
P.s. i live in ohio "hot" is 87degrees F. Those in warmer climates may have more insight.
Old Aug 25, 2013 | 05:10 PM
Rascally Wabbit's Avatar
2010 Mercedes GLK 350, 2001 BMW Z3 3.0 Roadster, 1997 Cherokee XJ
Out here in the Southwest, I find the mesh block to work well. Ours has the light coloured headliner & the almond interior. The max button will cool the interior quickly. Anywhere with a black interior will feel hotter.
Old Aug 25, 2013 | 05:15 PM
GINO-ESC's Avatar
Have the black interior and live in So Cal. Not a problem at all. You can always tint the roof
Old Aug 25, 2013 | 06:53 PM
Roof is already tinted is it not but it could be tinted darker. Wonder if the pano roof still has to be in the premium 1 pkg. Be nice if it was optional.
Old Aug 27, 2013 | 01:58 AM
Showa's Avatar
99' Lexus RX300-retired, 01' BMW 330i
The roof is not tinted. I have it tinted and added the mesh block so it blocks almost all the sunlight.
Old Jan 30, 2014 | 07:15 PM
Suz133's Avatar
Glk
Glk 350 2013
I just purchased a 2013 glk with 10,300 miles on it. Love it so far. Is there a way to tell via the computer in the car when and if it has had an oil change?
I am getting a message that Service A is overdue, not sure what this means.
Old Jan 30, 2014 | 08:04 PM
3k339A2lary's Avatar
Your best bet is to call your service dept & have them run your VIN. They should be able to pull up the maintenance records on it. Is your vehicle CPO?
Old Jan 31, 2014 | 09:16 AM
bop11's Avatar
350 GLK, C280
If you just purchased from a MB dealer he should have performed the maintenance and reset the warning. If you purchased it from somewhere else, get them to have it serviced properly. I think the only service with that mileage is the service A.
If service A was completed by other than MB dealer, you want to make sure they used the proper oil. Might be worth having a dealer do it no matter what to rave it recorded for warranty reasons.
Old Jan 31, 2014 | 09:26 PM
MKenM's Avatar
2010 GLK Black, Premium 1, Lighting, Multimedia, Appearance and Media Pkg, 2012 Corvette Grand Sport
First, where did you purchase it, private or thru a dealer? As previously stated if it was a dealer they should provide you with service "A" at no cost. It is not much more than the oil change and filter and a 27 point safety inspection. If it was private ask them if they had the oil changed. It should be synthetic oil and a MB oil filter or equal. MB does not use paper type filters.
Dealer "A" service depending on your area would be about $150. to $200.
