Std. vs. LED lighting not headlamps
Old Oct 19, 2013 | 05:36 PM
Rascally Wabbit's Avatar
2010 Mercedes GLK 350, 2001 BMW Z3 3.0 Roadster, 1997 Cherokee XJ
Our 2010 GLK has standard lighting, regular rear lights & round front fog lamps. Has anyone attempted to swap out the LED rear lamps & the LED front strip lamps from a year or two newer with the optional lighting pkg.? The latter will likely require the black backing plate too. Is this plug & go or is it more complicated than that? The best IMO is the the rear lamps with the yellow LED turn lights as found on the Euro market vehicles. Any help is appreciated!
Old Oct 19, 2013 | 11:40 PM
pnoyworx's Avatar
10 E63, Sold -07 E63
I think you will need to find someone who knows how to program the rear SAM to work with the LED tail lamps. I have no experience in this, but if you search the W204 section who are doing the swaps, require SAM programing.
Old Oct 20, 2013 | 01:40 PM
Thank you for the reply. Read through this link, all sixteen pages of it,
https://mbworld.org/forums/c63-amg-w...rofit-diy.html & the issues make it likely unfeasible. The SAM (signal acquisition module) is the bugger on the W204 model & likely the same would be experienced with the X204. The problem is with the programming of fog lamp activation.
Old Oct 20, 2013 | 09:17 PM
420tee's Avatar
Red GLK350, blue '87 Toyota Land Cruiser
Remember when all this stuff worked with switches? Easy to fix, easy to replace, lasted forever but all this junk is much better.
