2013 glk250 BT oil change questions
1) what's the torque spec for the oil filter and drain plug?
2) is there any torque spec for the plastic under pan screw?
3) where can I buy the oil filter wrench and the model no?
4) where can I find the service sheet, is it necessary to buy the the workshop manual from ebay?
thanks for the answers
I bought the correct oil filter wrench from ebay, try searching the forum, as I posted it with the ebay item number.
Don't forget to buy the metal washer for the oil plug when you buy the filter kit.
I have to recommend changing the oil from the bottom. From the top, I could only pump out about 4-5 L. From the bottom, I drained out 7.5 L.
I do not know the torque spec for the oil filter and drain plug, but I just did hand-tight. No issues so far. The plastic skid plate can be taken off without any torque specs.. just with regular handy tools.
The oil is relatively easy to change. Just take off the skid plate and loose the plug. The oil pours right out. Then change filter up top. And add the amount of oil you got out.
I bought my 74 mm oil wrench from ebay years ago.
A place to look is Harbor Freight Tools. Check online or in stores. They is ALWAYS a 25% off ANY item on their website. Print that out. The store and online sells the Mercedes-fit oil wrench.
My GLK has a Mobil 1 sticker on it that recommends Mobil 1. So that's the only thing it's been getting. I have had 0 problems.
also sent the first 10k factory oil sample to blackstone labs, and the result is ' high wear and silicon in new engines is common, along with potassium, should improve next time', so basically ok and I plan to test again at next change.
http://bevo.mercedes-benz.com/bevolisten/229.5_en.html
http://www.idparts.com/catalog/index.php?cPath=175 Cant wait to pick up our new 2015 GLK 250 BT ....4 weeks and counting
Until some guy tail gated us....we were at a light and the cop though he may have been going at least 50 mph. Now I have been doing these 13 hr. trips and the VW tdi is not cutting it. I was taking a lot of Advil. Hoping the 250 will take care of this a bit. Much better seating position I think.
