GLK Secrets
Old Oct 22, 2020 | 07:31 PM
  #51
Redcars's Avatar
GLK
Originally Posted by sethro1980
I really dislike the feature that shifts to park when the door is open. Several times I have needed to slowly drive with the door slightly open, but can't do that. I wish it was a feature I could disable. Also, I have never driven ANY automatic car or truck that rolled backwards on a hill when letting off the break. They all creep forward naturally. The only time I have experienced this is in a manual car.
So I had driven a lot of cars, and I noticed that on the 2011 GLK, When I come to a stop at a stop sign with no incline and let go of the brake, it barely creeps forward, almost as if it doesnt move. When it is on a slight incline, normal cars have no problem creeping up, but with the GLK, it doesnt move, and I felt that it was going to roll backwards if I didnt push the brake.
Old Oct 22, 2020 | 09:37 PM
  #52
3.5L's Avatar
2024 GLC300, 2014 BMW M235i
Is stepping on the brake pedal a problem?
Old Oct 25, 2020 | 02:02 AM
  #53
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
Info that is clearly noted in the owners manual
Old Oct 25, 2020 | 12:52 PM
  #54
3.5L's Avatar
A couple of other things come to mind. First, do you have the transmission set to "E" for Economy or "S" for Sport mode? When in the "E" mode, I believe
the car starts out in 2nd gear (locks out 1st gear). This might explain the lack of "creep."
Second thought: perhaps your transmission needs servicing, such as low fluid, dirty filters, etc.
