i-Pod connectivity solution anyone? Please help!
Instead, the vehicle has an older i-Pod 30 pin connector hidden in the glove box; tried an Apple 30-pin to lightning adapter today to no avail. Won't even recognize the thing. Tried an FM transmitter also but the sound quality is greatly diminished. The vehicle has no USB input either.
I'm wondering if anyone on the forum who has experienced the same issue could point me in the right direction? I've seen several gadgets already on the web that seem like a possible solution but some people claim they work while others claim they're not compatible. I'd rather avoid the hassle of trying everything out there if at all possible.
Your input will be greatly appreciated. Thank you in advance.
P.S. The vehicle does NOT come equipped with the Logic 7 audio system but rather the simpler one. No navigation. No back-up camera. Just bluetooth.
Thanks again for your input.
Something like this:
I have a different one, which takes CF memory cards.
I think this is the best way to play music on my '10 GLK.
Only issue is that I have to remember that the phone volume also works so it is not a fixed output.
I am lazy and don't care for trying to sync 5 different devices. Just hook it up to my phone and be done with it.
The BT reconnects automatically. And the remote allows you to FF etc without touching your iPod/iPhone.
Coupled with the Niteze ball mount it's about as convenient as possible.
And the audio sounds great, but then I mostly listen to BBC Radio 4 streamed over my phone. Music though sounds great too.
Aux-in doesn't usually allow for deck control, though.
If you already have the 30-pin cable, look for a 3 pin to lightening connector converter on eBay (http://www.ebay.com/itm/Lightning-to-30-pin-Adapter-Converter-Socket-Cable-Connector-For-iphone-White-/171653329361?pt=LH_DefaultDomain_0&hash=item27f755f1d1). That might allow full iPod connectivity (unless it won't talk to the iPhone OS).
I bought PCMCIA adapter and 16GB SD card. What it really needs is the bluetooth streaming.
