2010 GLK Misfire/Shaking
Old Mar 3, 2015 | 06:45 PM
krisgirouard's Avatar
2010 GLK 350 4Matic
2010 GLK with 99,000 kilometres...
Misfiring and shaking badly..
Non-MB code reader spit out:
Intermittent misfire in 1,2,3 cylinders
Bank 1 system too lean
Post catalyst fuel trim system too lean
P0301, P0302, P0303
Anybody have any experience with these diagnostics?
Recommended service was clean mass/airflow
Did that with carb spray, cleared codes..worked for couple hours, engine light is flashing again
any suggestions appreciated
Old Mar 4, 2015 | 07:37 AM
formerjeepguy's Avatar
2015 GLK350
Try cleaning it again - it may need replacing.
Old Mar 4, 2015 | 06:48 PM
2010 GLK 350 4Matic
Extended roadside towed it today...Dealer thinks it needs spark plugs replaced..Apparently quite common for glk.
320$ for the 12 plugs/labour...Also B service if 450$ here in New Brunswick Canada
Old Mar 5, 2015 | 12:04 PM
Wankafella's Avatar
GLC 300 4matic
quite common? :O I'll have to keep an eye out. So far I've been lucky with 110k km on mine. You think the massive snow/cold you got out there in NB this season could have exacerbated it?
Old Mar 5, 2015 | 12:12 PM
2010 GLK 350 4Matic
Couldn't say for sure, although it was -30 Celsius (wind chill) or colder for over 70 days....
Old Mar 5, 2015 | 12:24 PM
bop11's Avatar
350 GLK, C280
What gas are you using and did you buy some at a different station recently?
Old Mar 5, 2015 | 07:20 PM
2010 GLK 350 4Matic
No, same station, same fuel...I was suspicious of that myself!!
Dealer is replacing 6 plugs and an O2 sensor...
As well as both front struts and a 4 wheel alignment
Struts and O2 are covered by extended warranty, plugs and wheel alignment aren't....
168.99$ for alignment...lol
Old Mar 5, 2015 | 07:27 PM
erlomd's Avatar
2010 GLK 350 4MATIC
yep, sounds like your in need of some new spark plugs...i had mine changed at the 58,000 mile mark.
