CHIP Express Diesel Tuning Chip for GLK 250 BlueTec
http://www.chipexpress.com/products/4473/
I have a 2015 GLK 250 BlueTec and looking for a good plug in upgrade.
I'm also open to suggestions.
Thank in advance.
If you're open to suggestions, here a good one for you: don't f__k with it. There is no such thing as a plug-in upgrade. If there was free power to be had, Mercedes would have already given it to you. If you wanted a more powerful car, you should have bought the 350 gasoline engine model or moved up to an ML. If you wanted a more economical one to run, I am afraid I can't help you there as even a Prius is worse than the 250 Bluetec.
Also I would contact Terry from BMS before purchasing, he is very knowledgeable and eager to help.
terry@burgertuning.com
http://burgertuning.com/Mercedes_JBD...nce_tuner.html
Coming from a Chipped GTI, I can tell you that an engine tunes do make a significant difference with turbo engines. I think the manufacture would purposely detune their engines for product segmentation. For example I believe MB would loose some of the buyers for the GL 350 Diesel if they tuned the GLK 250 or the ML 250 to its full potential.
The second device mentioned is identical to the first in operation. By all means go ahead and use whatever you want on your car - just don't b!tch afterwards how there are issues with the car or that it's unreliable and that Mercedes won't pick up the bill for the repairs because you have voided your warranty. Caveat emptor.
While I realize this is not Rennlist or the C63 forum, that particular tidbit holds true for every vehicle ever made on this planet. Yes, some cars (usually with identical engines) were detuned for marketing reasons, and in those cases the extra power could be had without subjecting the motor to any stresses that it wasn't designed to cope with. The OM651 motor in the 250 with the twin turbos is at the top of the food chain for that particular engine. If you wanted to chip a Euro GLK 200 or 220 (with their 141 and 168 hp respectively), then it would be fairly safe to assume that you could try to get more power relatively safely seeing as the same motor is already producing more power in the 250 and Mercedes still stands behind it in terms of warranty. When you have the top-spec output for any given engine and you push it to give you even more, then you overstress the motor at the expense of reliability and longevity. It really is that simple.
I have first-hand experience with building, tuning ang blowing up race car engines for many years amd partially own an indie Porsche/Audi/VW performance shop, so take this for what it's worth. I don't mind spending some time on the forums helping others and being helped myself when I need it, but what I don't appreciate is when people come here asking for advice, others take the time to answer their questions, and then they don't like the answers and throw it back in your face. If you already know what's good or safe for yoru car, please don't waste our time asking about it and then arguing when you don't like the answers you get.
http://www.dinancars.com/product/d44...ries&mid=1233/
I have not had much experience with turbo diesels, so it might be different. But I am just curious what the difference is between the two.
In comparison, the OM651 motor in the GLK 250 has a compression ratio of 16.2:1 seeing as it's a diesel and thus has no spark plugs but instead uses pressure and temperature to make the air/fuel mixture spontaneously ignite. How much more pressure do you think it can safely take before you blow off the cylinder head? The injectors already squirt diesel in at 29,000 psi. As it is, it puts out 200 hp and 370 lb-ft of torque (for comparison, a Ferrari F430 produces about 345 lb-ft). Not much room for improvement there me thinks.
And, if you think that the BMW is somehow more advanced than a similar Benz, Mercedes already makes a 2.0L 4-cylinder turbo that puts out well over 350 hp / 330 lb-ft in stock form, in the A45 / CLA45 / GLA45. No aftermarket tuning required.
Diabolis, you seem to have a strong and informed option throughout the forum and I appreciate the perspective. I was just looking for other perspectives as yours was just the first answer of what I hoped would be at least several answers for my full consideration before making a decision either way. That is afterall my intended purpose of coming to a forum. It is also possible that a new and different technology or product is launched that you are not yet aware of and is worth exploring so if someone on this forum is aware of such a product, I along with others would certainly like an opportunity to be introduced to it so we can all take the time to learn more about it.
That all said and in the end, I may ultimately end up leaving this vehicle stock in consideration of the warranty and the fact that it's the practical family vehicle of our fleet at home but I intend to take it all in before making a decision.
I trust that we can all agree that it would still be nice to make this vehicle even just a little more enjoyable performance wise than it already is so perhaps another question could then be what other performance mods aside from engine tuning would be worthwhile but I'll just start another thread for that.
Thanks again and don't be afraid to keep your contributions and perspectives coming on this topic. I value and appreciate it all.
