OK to Connect Trailer Lighting Power to Auxiliary Battery?
I am installing a hitch on my 2013 GLK 350 and need to connect the power wire for the power module (protects the vehicle wiring from a bad or incorrectly wired trailer) to the battery. I was looking for a good way to route this wire up to the front batter and in the process discovered the auxiliary battery in the back, near the spare tire. Also noticed the small battery is fed from a relay of some sort that appears to have a connection from the front battery as well as the connection to the rear battery. The relay seems to act like a switch allowing the alternator to feed the aux battery, as needed.
My two questions are 1) is it okay to use this small battery for my trailer lighting module power, and 2) recommend connecting to the battery connection on the relay or on the front battery/alternator connection?
Thanks everyone.
KSWitwer
Thanks everyone.
KSWitwer
that auxiliary battery is a buffer battery for the stop/start function. i would try to hook up somewhere else. there are plenty of empty slots in the rear sam fuse box right there.
Thanks everyone.
KSWitwer
Thanks everyone.
KSWitwer
