2014 Mercedes-Benz X204
Old Feb 1, 2016 | 07:50 PM
sancheztech's Avatar
2014 Mercedes-Benz GLK350
Smile 2014 Mercedes-Benz X204
Hello Friends, I need some help on the following:
I recently bought a 2014 MB GLK350 and had broken steering rack, I went ahead and replace it with a used one. It works fine but once it reaches speed the steering gets hard and difficult to control.
The GLK did had a airbag error because of the accident but not sure if it trigger some default mode; now the dealer does not want to re-program the used rack because its hard coded.
Can someone advise if a used electric steering rack can be reprogramed and why when it goes speed it get hard to control steering?
I appreciate very much.
Old Feb 3, 2016 | 05:39 AM
carid's Avatar
PREMIUM SPONSOR
Mercedes E55 AMG E211
Welcome to the club and congrats on your MB! Show it to us when you can. You've came to the right place - this site is a great resource with tons of useful information and knowledgeable guys. With a little bit of research you can find an answer to all your questions.
Old Feb 3, 2016 | 09:47 AM
dbldpr's Avatar
Veteran: Navy
Welcome
Old Feb 4, 2016 | 12:35 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to X204 forum...
Old Feb 5, 2016 | 12:04 PM
bop11's Avatar
350 GLK, C280
Sounds more like a problem with the front wheel geometry. If the accident caused a broken rack, it probably bent some links and sheet metal which could cause a caster, (supports high speed stability) or camber (vehicle handling) problem. These are not easily adjustable on the GLK and rely on the sub-frame and body to be correct, unlike pre 90's cars. Have a good shop check the alignment of this vehicle. Even Toe setting could be affecting the high speed handling.
