engine mounts
Old Sep 2, 2016 | 10:14 AM
monarc98's Avatar
04 c240 avantgarde,2011 glk 300
engine mounts
hi all,
just curious, do you need to separate the engine from the tranny to replace the engine mount. local mech is saying this and not sure if he is just trying to make it soud a lot of work to jack up the labor cost more because of that. thanks folks
Old Sep 2, 2016 | 08:20 PM
monarc98's Avatar
Here you go
Old Sep 4, 2016 | 05:32 AM
Sam.P's Avatar
'06 E55 / '10 GLK 350
No, I've done them myself and the only things you need to remove are the alternator/compressor (just needs to be unbolted from the block) and both front axle shafts if your car is 4Matic. Unbolt the two mounts then lift the engine from under with a jack just enough so you can fit the new ones in.
Old Sep 4, 2016 | 06:03 AM
monarc98's Avatar
Thanks sam p I was told the same thing but decided to hold the repair coz the labour charged Increased and they won't be able to get it done the same day. I will have to reschedule this
Old Sep 21, 2016 | 11:46 AM
monarc98's Avatar
FYI engine mount and tranny mounts replaced and car is running super smooth. I more shake your headlights. Thanks you all
Old Sep 27, 2016 | 10:37 PM
AzCamel's Avatar
10 GLK350/ 15 Accord/ 94 Supra Turbo
what was the cost for just the parts and just labor?
Old Sep 28, 2016 | 06:18 AM
monarc98's Avatar
Here where I'm at cost me a little less then usd 200 for the parts . Labor was a bit cheaper 215 usd
Old Sep 28, 2016 | 01:03 PM
AzCamel's Avatar
OEM parts? Thanks
Old Sep 30, 2016 | 03:04 AM
monarc98's Avatar
Correction on the cost it's 297 usd for labor and around 225 or less for the mounts 3 pcs. Yes all original got decent price from benz store (reseller)
Old Sep 30, 2016 | 01:05 PM
AzCamel's Avatar
Thank you
Old Sep 30, 2016 | 07:10 PM
nathankershaw's Avatar
2011 Mercedes GLK & Merkur XR4Ti
Just did it on a 2WD model:
Old Oct 17, 2016 | 03:34 PM
rj4logan's Avatar
2004 Mercedes E55 AMG
I replaced all 3 motor mounts (2 front and transmission) in December 2013. Only 24,000 miles on the odometer since the replacement. I have learned that I need to replace them again. I have no doubt about the competency or honesty of the mechanic. He said that he was not surprised and that it was highly unlikely that it had anything to do with my driving.
Has anyone else experienced such a short life for your motor mounts. I have a 2004 E55 AMG with 101,000 miles. It has an R1 RennTech package (if that has any bearing on this issue, which does not seem likely)
Old Oct 17, 2016 | 04:48 PM
LesF's Avatar
2014 glk 250BT (RIP, 3/1/17}, 2010 C300
I had a 98e and an 05e and both went thru motor mounts. the 98 2 sets over 105k miles and the 05 85k. It's a common issue with Mercedes.
Old Oct 17, 2016 | 04:52 PM
Hugo L.'s Avatar
2014 GLK250
What are the symptoms of bad motor mounts?
Old Oct 17, 2016 | 05:21 PM
rj4logan's Avatar
Deleted
Old Oct 17, 2016 | 05:22 PM
rj4logan's Avatar
I appreciate the response. I will resign myself to this expense every 25,000 miles.
Old Oct 17, 2016 | 08:33 PM
LesF's Avatar
Old Oct 17, 2016 | 08:35 PM
LesF's Avatar
The engine feels like its sitting on the frame when running and you can feel it as a vibration when you're stopped not the isolated ride you expect. You also can check the mounts visually and look for hydraulic oil spots.
Old Oct 18, 2016 | 12:22 AM
AzCamel's Avatar
Easiest way to diagnose motors mounts is open the hood, have someone inside the car with it running, tell them to hold the brakes all the way dow, put it in drive and blip gas, if the engine moves up/down or sideways then your mounts are bad, especially if the engine looks like it wants to jump out of the engine bay. Another way to tell is put the car in drive and see if there are vibrations, then neutral and see if it goes away.
I had to replace all the mounts on my old E500 bit it did last 100k.
The issue is with the hydraulic design of the mounts, most cars with this design like my 08 Acura TL will cause failures much faster then normal, I would gladly use non hydraulic type for a little bit more vibration for longevity
Old Oct 18, 2016 | 03:26 PM
Hugo L.'s Avatar
2014 GLK250
Ah, thanks for the info. My car just hit 60k miles, and so far so good.
Old Oct 28, 2016 | 07:16 PM
mjhawkins2346's Avatar
2016 GLE300d 4Matic
I guess I'm lucky. I have 111k miles on my 2010 GLK 4matic on the original mounts.
Old Oct 28, 2016 | 10:54 PM
sethro1980's Avatar
2013 GLK 350 4Matic
Mine got replaced at about 30,000 miles. 2013 GLK350 4Matic.
Old Nov 15, 2016 | 08:56 PM
NYCGLK's Avatar
GLK 350 / Porsche 993
Same here 2010 with 70k miles, but I do notice a very slight vibration, which I think is an indication of the mounts wearing out.
Old Dec 29, 2016 | 04:13 PM
rmfnla's Avatar
2013 Infiniti G37 Coupe; 2011 GLK 350 w/ Premium 1, Multimedia & Sport Appearance; I LOVE IT!
My 2011 needs new mounts at 36,500 miles and I am furious.
The dealer quoted me almost $1,800, most of which is labor, and won't pitch in on the cost at all.
I will probably just do them myself since it doesn't look like too bad a job.
I have read too many accounts of this for it to be anything other than poor engineering.
The Best or Nothing my a$$...
Old Aug 30, 2018 | 12:21 PM
jroach's Avatar
2010 GLK
Does anybody have any experience with this tool:
Seems well worth the money if it keeps me from unbolting all the other parts I've read about.
I have a RWD GLK 350.
