driver side rear side marker light issue
Hey all, i recent purchased a 2011 mercedes glk350 and love it. Since I purchased it there has been one issue. The driver side side marker light in the rear does not light up. I was made aware of this via the on dash notification. I figured no big deal, probably a bulb. However, the bulb is not burned out. I confirmed this by trying it in the other sockets and the passenger side. So i figured it must be the bulb socket assembly. To test this i swapped left and right sockets and when i plug the passenger side socket into the driver side it lights right up, no matter which bulb i try. Also, when the driver socket is plugged into the passenger side, no go, it does not light. I thought for sure this would confirm a new driver side socket is needed. I ordered one and sure enough, when it arrived, i had the same exact issue. Even with the new driver side socket it does not light the side marker bulb (and i tried several) on either driver or or passenger side. Now im at a loss. What should my next step be? Is it possible both the old and new socket was bad and i just need to try another one? Please send your suggestions my way. Merry Christmas!
i forgot to mention in all cases the rear fog light, which is the high beam of the bulb in questions, does indeed work. very odd.
