DEAD GLK350. NEED Advice/HELP
Old 12-28-2016, 12:22 AM
Roman_011's Avatar
2012 MB GLK350
Question DEAD GLK350. NEED Advice/HELP
Hello, I bought 2012 MB GLK350. Has 40K miles. Changed oil, spark plugs, passed smog and on the way home car died. tried starting while rolling (in neutral) nothing. no crank...
To make a long story short. I replaced a starter and a battery (per mechanics advice) still can't start. Engine would turn then dies. No codes coming up. I was told I have to replace an engine. That would cost me another $4-5K.
Please advice if had same issue. I don't know what to do.
Old 12-29-2016, 10:04 AM
Super Moderator
MJ50's Avatar
bone stock E55 AMG
moved to X204 forum...
Roman_011 (12-29-2016)
Old 12-29-2016, 11:22 AM
Mmr1's Avatar
2013 glk 350
I'm not a mechanic but there are lots and lots of things to check before you even remotely consider a new motor. First is replace the mechanic . There should be codes to read or maybe it's a computer issue. Check if it's getting gas, and spark. Did it die abruptly? Does it attempt to fire? It could be many things , even real bad gas! Do a compression test before being sold a motor. Computer modules are cheap on eBay , new modules may have to be coded to your car at MB and end up costing 10x more than used. Does it fire up at all?
Old 12-29-2016, 03:19 PM
Roman_011's Avatar
2012 MB GLK350
DEAD GLK350
Engine died while I was driving on one lane street with soft curb and basically no place to pull over and stop, so while rolling with dead engine I tried multiple times to start the engine to no success.
No crank. No crank. No Check Engine. No codes.
After I replaced starter and battery it cranks but doesn't fire. Filled up with 91 Chevron.
Had two mechanics check the car and was told that chain broke. Waiting on third to call me.
Old 12-29-2016, 04:16 PM
rmfnla's Avatar
2013 Infiniti G37 Coupe; 2011 GLK 350 w/ Premium 1, Multimedia & Sport Appearance; I LOVE IT!
Timing chains rarely break, especially at 40K miles. Maybe time for a M-B dealer to look at it?
Do you have any recourse with the person who sold it to you..?
Old 12-29-2016, 05:34 PM
Mmr1's Avatar
2013 glk 350
400,000 miles?
Old 12-29-2016, 08:23 PM
Rocman8's Avatar
E55
Did you put oil in it? What filter did you install?
Old 12-30-2016, 04:28 PM
Roman_011's Avatar
2012 MB GLK350
400,000 miles?
No sir.
Attached Thumbnails DEAD GLK350. NEED Advice/HELP-image000000.jpg
Old 12-30-2016, 04:30 PM
Roman_011's Avatar
2012 MB GLK350
Bought everything from MB. YES on oil.
Old 12-30-2016, 04:34 PM
Rocman8's Avatar
E55
What does the filter style look like this is very important.
Old 12-30-2016, 04:41 PM
Roman_011's Avatar
2012 MB GLK350
Two of those. Bought them at local dealer.
Attached Thumbnails DEAD GLK350. NEED Advice/HELP-img_20161230_133729.jpg   DEAD GLK350. NEED Advice/HELP-image000000-1-.jpg
Old 12-30-2016, 04:42 PM
Rocman8's Avatar
E55
im talking about oil filter
Old 12-30-2016, 04:45 PM
Roman_011's Avatar
2012 MB GLK350
Looks like that.
Attached Thumbnails DEAD GLK350. NEED Advice/HELP-s-l225.jpg
Old 12-30-2016, 04:51 PM
Rocman8's Avatar
E55
Ok did the o rings get installed correctly so the oil is distributed properly? This is a very strange situation to just need a motor at 40k.
Roman_011 (12-30-2016)
Old 12-30-2016, 05:02 PM
Roman_011's Avatar
2012 MB GLK350
Yes sir. Like I said, I was driving and then...
Just remembered. When i pulled over and open the hood there was electrical burn scent. I thought that it was some fuses, but later mechanic told me that starter was gone.
Old 01-01-2017, 04:34 PM
eki912's Avatar
GLK 250 Bluetec
So battery is new ? Starter works too ? Cranks ? Engine turns while you crank it ?
and you mentioned a smell ?
Could it be an electronic unit blown ? Ignition / injection module gone ?
Old 01-02-2017, 02:44 PM
cindyclk's Avatar
I usually don't say this but it is time to go to dealership...pay for an hour labor to do the diagnosis.
Old 01-04-2017, 10:42 AM
bop11's Avatar
350 GLK, C280
If the timing chain broke, the engine wouldn't turn. I don't believe the 350 is a clearance engine. So you can probably rule that out. Sounds more like a key fob, security issue, or a bad connector to the computer. Do you hear the fuel pump run? If the car was run out of gas a few times it may have a bad fuel pump.
Check for fuel at the injector, then spark during cranking.
Old 01-04-2017, 11:35 AM
Mmr1's Avatar
2013 glk 350
It's weird no codes, maybe computer ? You need a real MB mechanic to look at it
Old 01-04-2017, 04:10 PM
Hugo L.'s Avatar
2014 GLK250
Maybe the obvious : bad fuel pump? If the engine cranks but won't start, fuel might not be getting in it.
Old 01-04-2017, 07:20 PM
mjhawkins2346's Avatar
2016 GLE300d 4Matic
You don't need to go to a dealer but you need a Mercedes trained mechanic with a Star System who can do some serious code pulling and testing. Your efforts, or rather your mechanics efforts sounds like amateur hour, frankly.
I would look on Yelp, as an example, for a local mechanic with high skills and recommendations. Anyone who says the starter is gone after it cranks should be gone themselves. If you smelled a burnt wire smell that would be revealing. You might have fried part of a wire loom that, if you're lucky can be replaced as a segment. Again, a Star System analysis can point this out quickly to an experienced mechanic. Don't accept any, "You need to replace your: timing chain, oil, engine, starter, etc. " recommendations without an in depth explanation. Too many mechanics know just enough to be dangerous and want to go bobbing for dollars under your hood. Good luck.
Roman_011 (01-06-2017)
Old 01-06-2017, 03:10 PM
Roman_011's Avatar
2012 MB GLK350
Exclamation UPDATE. DEAD GLK 350
Thank you all for advises you've given.
Here's status update.
Had a few mechanics look at the engine and they tried turning flywheel with wrench. Dead. Not turning.
Had spark plugs taken out and tried again. Dead.
One of them had laptop connected to the car and that's how we found out the starter was burned, there was no signal from ignition to the starter through fuse. Dead. Fuse was good.
Based on flywheel not turning they all came to conclusion that either chain pulley malfunctioned and end up braking or bearings.
When battery is charged, I only get one chance of turning/starting the engine, and I hear metal scratching sound inside engine for a second, and I have to charge battery again.
Old 01-06-2017, 04:25 PM
spyked's Avatar
2013 W204, 2015 X204
Have you taken it to an authorized Mercedes Benz dealer? If so, which one? They can't help you with goodwill if you don't give them a chance.
Old 01-06-2017, 04:34 PM
Rocman8's Avatar
E55
+1
We are missing something to the story here about the history of the vehicle. This doesn't just happen.
Old 01-08-2017, 08:59 PM
Roman_011's Avatar
2012 MB GLK350
OK. Had a guy with different scanner come yesterday. Not finding any codes (of course) tried turning the key. Engine cranked but after hearing the metal scratching sound he's reply was it's not the engine, it's your torque converter.
I bought that GLK of a car auction with flood certificate. Because i didn't drain transmission oil () corrosion did it's work. There was no water in engine oil when I drained it, but still I replaced spark plugs, air and oil filters including cabin filter. I don't know what I was thinking...
I'm gonna have transmission guy look at it and by the end of the week I should know final result.
Quick Reply: DEAD GLK350. NEED Advice/HELP
