Brake labour
Old Apr 24, 2017 | 01:16 PM
guMBy's Avatar
GLK350
Brake labour
Does anyone know what the flat rate amount of hours a shop would charge for labour to do the front pads and rotor on a GLK? Isn't there a book shops use to look up the customary amount of time to charge for the job?
Old Apr 24, 2017 | 07:22 PM
B737's Avatar
2012 GLK
if you are the least bit mechanically inclined, i encourage you do this yourself if you have the interest, tools, time and space. doing brakes on a GLK is really very easy. We did pads and rotors on all four wheels in under two hours, it was only two of us working at a casual pace.
Old Apr 24, 2017 | 08:01 PM
JohnnyC's Avatar
2015 GLK350 & 2020 C300
if you are in the los angeles area i could help ya
Old Apr 24, 2017 | 09:39 PM
guMBy's Avatar
GLK350
I haven't done brakes since I did them on my Infinity QX4. They were a big pain in the a$$. You had to set preload on the bearings, and you had to separate the hub from the rotor but I managed. I have already got a set of Zimmerman rotors and Ate pads for the GLK. I was looking at my floor jack when I went into the garage and it looks like the seal has failed so I would have to buy a new one. I was thinking if an independent shop would only charge a couple of hours it might be worth bringing it to them. I checked youtube and saw a couple of how-to videos for GLK brakes and it really seems easy. I might just get a new jack, some Etorx sockets and do it.
Old Apr 25, 2017 | 12:52 PM
Angel Nunez's Avatar
Glk 350
Labor Cost me $85 for the front but I spent $170 for the original brake rotors and pads which I regret because they create so much dust ......
Old May 4, 2017 | 01:23 PM
guMBy's Avatar
GLK350
Finally did it
Well I finally collected all the stuff to do the job and did it last weekend. It was very easy. The hardest part was loosening the caliper carrier bracket bolts. After the first six or seven stops the brakes sounded and felt pretty good. Now, after a couple of days and several hundred kilometers they feel great. It's nice to save the money on labour and get the satisfaction of doing the job yourself.
Old May 4, 2017 | 05:39 PM
B737's Avatar
2012 GLK
good work man!!
