2012 GLK 350 Transfer case or Transmission problem. ~HELP~
Old Jan 27, 2018 | 04:41 PM
sunwave's Avatar
2012 glk 350
Unhappy 2012 GLK 350 Transfer case or Transmission problem. ~HELP~
Hi, I have a 2012 GLK 350 with 28990 miles on it. Recently there is swoosh sound when driving in a low speed, and i feel shudder/vibration when doing the sharp turn.
I searched the internet , seems like many owner has same problem because of the faulty transfer case and transmission.
My car is out of warranty already, any suggestion for either fix it or trade it in? the reason i am thinking to trade it in is i am afraid of same thing might happen again after the car is fixed.
I don't even know if i could trade it in at this point because of the transmission issue.
If I take it to dealer to ask them to fix it. what would be a reasonable price? 8k? 7K?
if the cost is a lot cheaper, will it be okay to take the car to non-dealer workshop for repair?
need your help! any advise is appreciated.
Old Jan 29, 2018 | 09:33 AM
bop11's Avatar
350 GLK, C280
Assuming it is in good value, it probably will trad at around $16,000 usd. If you take that $8,000 for repair, you can break even at around $24k with either a new other brand new car or a loaded 2015 GLK CPO with maybe 40k or less miles but a 3 + 1 year unlimited mileage warranty taking you out to 2019.
Old Jan 30, 2018 | 08:28 AM
Mmr1's Avatar
2013 glk 350
When did you last check all fluids, and there are no leaks anywhere, your sure
Old Jan 30, 2018 | 10:34 AM
KC61's Avatar
2013 GLK350 4-Matic
Man, that's low miles to have an issue like this already. I would have it checked out by a transmission shop instead of a dealer. We have Certified Transmissions around here and they are very competitive on pricing for replacement transmissions if that's the problem.
Old Jan 30, 2018 | 06:12 PM
Mmr1's Avatar
2013 glk 350
That might be a universal joint or CV joint, a much cheaper issue , don’t wait if it is a CV joint, you don’t want it to break and leave you stranded.
Old Jan 30, 2018 | 08:46 PM
sunwave's Avatar
2012 glk 350
Thank you for the reply!
after reading other replies , now i am more leaning towards fixing it. I am gonna take it to 3rd party shop to do a estimate and most likely gonna fix it there.
I 've read a lot of negative reviews of near by MB service center. Many people got their car fixed outside for a fraction of money of a dealer quote.
Old Jan 30, 2018 | 08:53 PM
sunwave's Avatar
2012 glk 350
I haven't checked any fluids except taking it for oil change. The cause of the problem could be the leaking fluid, right?
I am gonna do a thorough check when weather gets a little better.
Do you know if it is necessary to warm the car first before driving in winter months? i never do that
Old Jan 30, 2018 | 08:54 PM
sunwave's Avatar
2012 glk 350
you are right, I am gonna try that. thank you!
Old Jan 30, 2018 | 08:55 PM
sunwave's Avatar
2012 glk 350
thank you for the heads up!
Old Jan 30, 2018 | 09:10 PM
Mmr1's Avatar
2013 glk 350
The CV joint connects the axle to the wheel, it flexes. If the sound is with each rotation it could be a bad cv joint, oil is different that is internal. You need to get someone to check it out . It could be under 500 to fix, CV joints eventually break when they go bad , so get a good regular mechanic , not a transmission shop, just a good local guy to look at it.
Old Aug 17, 2019 | 12:31 AM
douglas_scott's Avatar
2011 E550 Coupe
Apparently this is a pretty common occurrence - transmissions being ruined abruptly and without warning by coolant getting from the radiator into the transmission.My service advisor at a large dealership in Dallas told me it used to be an epidemic in earlier years (2000 - 2010). It just happened to my 2011 E550 Coupe (only 61k miles) last week. Was fine on Thursday and trembled on every up-shift on Friday. I parked it and took it to the dealer on Monday and was given the same diagnosis as LadyS, and a similar repair cost of $10,800. I did not even think for a minute about spending that to repair it, even though I've really liked the car for the 4 years I've owned it.
Is repairing, rebuilding, or replacing with a rebuilt transmission a much lower cost and doable alternative in this kind of situation? I know for most other makes and models transmission repair or replacement is pretty common. Of course, this is porbably more complicated and more stuff to contend with and connect to make it just right, but it's hard to believe that, as much as this apparently happens, it's not easy to locate Mercedes transmission specialists.
Anybody know of transmission shops in the Dallas area with significant experience in this kind of work for Mercedes transmissions?
Thanks.
Old Sep 12, 2019 | 08:05 AM
Travelness's Avatar
2010 GLK350 4Matic
I'm noticing a slight klunk when getting off the gas sharply, and suspect it is the transmission mount. In looking at the mount design, I may purchase a new mount but do some modifications to it which may make it a bit more robust.
