Finally got it done - GLK250 DPF/SCR Deleted and EGR disabled
I got a notice in the mail that I need my airbags swapped. I’m just concerned if I took my car to the dealer and they plug their computer in they would revert my time back. Is this something that could happen. Should I be concerned about that.
thanks
Now when they call you in for the "fix" that'll be a different story.
I am still debating if i should do the recall.
They also noted the RF tie rod has a bit of play and will need replacing. No charge on alignment, no other issues.
I made sure to hook up my Noco trickle charger before doing the reading/rewriting. I'm on the original 2014 battery, and I know it's weak. You don't want power issues while coding new software.
Also correct: it doesn't matter the brand of exhaust pipe. What matters is the tune. With the OETuning software, the car will still do regens when it thinks it needs them. If you remove hardware, you have to have a tune that stops any/all regens because without a DPF in place, you're likely to burn a hole in your new exhaust.
The best route, IMO, is to not need surgery on the car which isn't really reversible, whereas a tune is. Plus it's cheaper.
I am in Toronto, can anyone recommend a shop nearby?
Again, my condolences to our Cannuck members...
