Diesel particulte filter clogged
Second recommendation is to try a fuel additive. Apparently they can help the soot burn off at a lower temperature. Never tried these, but worth Googling to get more experience:
https://www.hypermiler.co.uk/dpf-die...-actually-work
Replacement apparently very expensive.
My DPF clogged at 18K miles. Way too early.
https://www.mbusa.com/vcm/MB/Digital...on_booklet.pdf
I was counting on the 8 yr emissions warranty and my 7 yr extended warranty to allow us to keep our GLK for a while yet. But I could not find Mercedes Canada equivalent of MBUSA warranty document.
The DPF can be cleaned if it is removed. I understand it is fairly common on large diesels and even their smaller Mercedes sprinter kin. If I understand it correctly they pneumatically clean it then bake it for 8-10 hours, then pneumatically clean it again. If you can find an independent shop willing to remove the DPF and take it to a truck center for cleaning then it would still probably be cheaper than the parts and labor for a DPF delete. You should only be down for a few days.
For the years i live in Toronto. There are lots of shop that offer guarantee to pass the emission test. Give kijiji a search, you will see it.
Another alternative.
