GLK Transmission control module Tcm problems
I was driving home from work and noticed my engine light on. Then I started to notice that I couldn’t accelerate as fast. Driving city wise, it was manageable , but super slow take offs. My code reader says transmission control module 3y/8n4. My most recent research shows that only the dealership can install one since it has to be programmed by them. And it’s a very common problem amongst newer. Mercedes .
any one have a solution to fix it ?
There are "rebuilders" on Ebay and places that will sell you a "virginized" TCM that can have the initial startup performed by a properly enabled SDS, but there's no way to DIY it.
It's not a terribly expensive part, replace it and carry on with life. This isn't something you want to be doing over and over again, and driving the car in limp mode for any length of time can cause severe mechanical damage in the transmission if it's already getting worn, best to fix it sooner than later.
