Car wont crank, "remove key" message
Old Oct 22, 2018 | 11:29 AM
celiboom's Avatar
Mercedes GLK 2010
Hi, my mercedes glk 2010 is acting up this morning. I came to my GLK this morning and window was a bit down about 1 inch (can't remember if I closed it 100% last time I tooked the truck)
however, I put the key in the ignitiion and I was unable to roll the window up. then I tried to start the car and nothing..... the dash indicate me to "remove the key". We bought a new battery 1 month ago but Just in case, I tried to jump start the car and nothing more. I also tried to use our 2nd key with no luck.
Is this a common problem with GLK ? car is not even cranking or trying to start
thanks a lot!
Old Oct 22, 2018 | 12:29 PM
bop11's Avatar
350 GLK, C280
Try moving the shifter. It may be the neutral switch
Old Oct 22, 2018 | 01:27 PM
celiboom's Avatar
Mercedes GLK 2010
I tried to move it as much as possible, did the same with the stearing. when you put the key in you hear a little clic noise but the stearing isn't unlocking. the gages remains to 0 but they light up.
Old Oct 22, 2018 | 02:47 PM
Marek_Norway's Avatar
2009 GLK 220 cdi
If the steering wheel doesn't unlock when you put the key in, it is ESL (electronic steering lock)...check the internet for this problem, it is very common on C and GLK class (W204, X204) and expensive repair in dealer...I had this problem this summer, my GLK is 9 years old and has 200000 km on...check this - https://mbworld.org/forums/c-class-w...lots-pics.html
I was able to unlock the steering wheel after few hits to steering column/shaft, then I removed ESL and changed the motor in it (the whole repair cost me 40 dollars)
Old Oct 22, 2018 | 05:27 PM
Mmr1's Avatar
2013 glk 350
Put a volt meter on the battery to verify charge. You need about 12.75v . I’ve seen defective batteries that won’t take a jump. Try charging with a charger if low.
Old Oct 23, 2018 | 11:32 AM
celiboom's Avatar
Mercedes GLK 2010
Thanks a lot everyone, I just got a call from the local repair shop and they said it was the ESL and they can't change it because it need to be reprogrammed at the dealer. They are offering me to tow it to the nearest local dealer. @marek, how hard was it to repair? How much time it took to do?
I will call my dealer to know if they can fix it without spending 1K ++
Old Oct 23, 2018 | 11:35 AM
celiboom's Avatar
Mercedes GLK 2010
Quick question, where did you hit the stearing column to unlock it? you hit above the wheel? under? If I could get it to start again, I could at least get it back home to try DIY !
Old Oct 23, 2018 | 11:57 AM
andreigbs's Avatar
GLK 250
I would try the top of the steering wheel, centered and straight down.
When I had this issue on my C300, it cost about $2K at the MB stealership. That was 4 years ago.
Old Oct 23, 2018 | 03:22 PM
2009 GLK 220 cdi
You need to take down plastic cover over the pedals, then you can see the steering shaft, one part of it is thicker then the rest of it, there you need to hit it, the steering lock is on the oposite side of this place. Hit it with the rubber or normal hammer, then insert the key into ignition, but don't turn it if you won't hear characteristic sound for it...try it few times - hit and insert, hit and insert...if you will hear the sound, you won, you can start the engine, you can drive it, you can stop the engine, but don't remove the key from ignition...I drove my glk 2 weeks without removing the key, but you can't lock the car if the key is in...when you will be ready for repair, disconnect the battery with key in, ELS must stay unlocked, then you can remove it from steering shaft...
If you won't unlock the steering, then the EIS (electronic ignition switch) is locked electronically and even if you remove the ELS and change the motor, you will have to find somebody with the computer for unlocking the EIS...I was lucky, my EIS stayed unlocked (EIS is driving unit, you put the key in it and it is paired with ELS. After couple of unsuccesfull attempts to unlock the steering wheel locks itself).
The whole job took me around 3 hours, but I removed airbag, steering wheel, steering column and the steering shaft, for second time I would go without removing airbag and steering wheel, I would remove steering shaft with wheel and bag on it...I have also knee airbag, it was little obstacle, harder to move around with tools...
https://www.pelicanparts.com/techart...eplacement.htm
Good luck...
Old Oct 23, 2018 | 05:53 PM
Mmr1's Avatar
2013 glk 350
If you get an esl from a junkyard that’s from the same model you won’t have to have it programmed,
Old Oct 24, 2018 | 12:43 PM
B737's Avatar
2012 GLK
if its the ESL, i would bring the car home, remove ESL, and have it exchanged for a black box, there are guys on the forum who will do it for you, and on ebay too. no more ESL....
204 C CLASS GLK ESL/EIS steering lock REPAIR or DELETE https://ebay.us/wH0xhA
Old Jan 24, 2021 | 07:21 AM
Pete McKinnis's Avatar
c300
C300 Mercedes 2010
Parked my car last night and when I went back a few minutes later the car would not start. When i put key in the ignition there is a message that says remove key from ignition. However, the vehicle will not start and Im not sure what to do. I did the usual by checking to make sure the vehicle is in park but still not response.
Pls provide me some instructions as to what to try.
Thanks,
Pete McKinnis
Old Jan 24, 2021 | 11:50 AM
Mmr1's Avatar
2013 glk 350
How old is the battery, do you have a volt meter, check it. Do you have a battery charger with AGM cycle? Use it.
Old Jan 25, 2021 | 11:31 AM
andreigbs's Avatar
GLK 250
It's possibly the ESL.
Old Apr 15, 2021 | 02:29 AM
RettBergmark's Avatar
2001 CLK
REMOVE KEY message
My 2001 CLK Mercedes was parked all day. When I returned, I unlocked the doors with the battery powered fob/key. I sat in the seat, put the key in the ignition and a warning light appeared with a large key on the display with the words "REMOVE KEY" on it. The key would not turn and therefore the car failed to start. I removed the key, tried again and each time I would get the REMOVE KEY message. Is it the key or the car?
Old Apr 15, 2021 | 09:45 AM
andreigbs's Avatar
GLK 250
Try the CLK subforums. I believe it's W208 for your year.
Old May 2, 2021 | 10:14 PM
james182hill's Avatar
2010 Mercedes C300 4Matic Luxury
Help please
so if I buy one from the junkyard and just replace the old esl with the new one I won’t have to replace the lock or get it programmed? Sorry just wanna make sure before I buy it cause taking apart the esl worries me.
Old May 3, 2021 | 10:31 AM
Mmr1's Avatar
2013 glk 350
A friend of mine that repairs his mb replaced his transmission computer with a junk yard unit, he said it worked fine with no programming a new one would need, I can’t say for your application. It is a cheaper way to try it.
Old May 3, 2021 | 12:53 PM
thanks, I think I’m gonna just try and replace the motor in the esl myself. Doesn’t look to bad plus the cars far in the country away from dealerships, shops, and towing companies.🤦🏾‍♂️
