2011 glk350 V6 timing chain
Otherwise everything else is a guess.
No engine code for stretched chain.
I paid $3700 for the balance shaft, timing chain, rear main seal and I think he said some timing chain cover, can’t recall. This is parts and labor. ( dealer tech side job) Only thing I would have wished was done at the same time is the motor mounts.
Edit: All parts replaced were as follows: Crankshaft Sprocket, valves for camshaft adjusters, camshaft expansion plugs, centrifuge housing cover, oil cooler seal, thermostat and gasket, timing chain, pulse wheels, timing chain tensioner, oil filter housing gasket, resealed upper and lower oil pans and replaced rear main seal, new exhaust clamps. Fluid on bill was 16 quarts oil, 2 gallons of coolant, 1 quart of power steering fluid, 1 quart of differential fluid. total for parts was $1750
Last edited by Billybenz801; Feb 2, 2019 at 08:05 PM. Reason: added info for future reference
What were the symptoms for balance shaft replacement? I thought those issues were related to earlier engines.
OP,
What are you symptoms? How do they know chain is stretched?
I was getting codes, P0016, 1208, 1200. I thought it was related to earlier engines as well. If OP does pull the engine or if any of you pull the engine, make sure to do engine mounts, I’m stuck doing them now not even 1k miles after doing the balance shaft and it would have been a lot cheaper and easier to do it while the engine was out. My timing chain was still in good condition when it was removed, I changed it as a precaution. The chain was only 300$ and my mechanic installed it for free because he had to take my old chain off to do the balance shaft anyway.
