2014 GLK 250 will not shift into gear from Park
Old Jan 31, 2019 | 11:31 AM
HONDO250's Avatar
GLK250
During the recent Cold Weather In PA, GLK will not shift into Reverse or Drive, just stays in Park
Diagnostic Code shows no dysfunction present
Old Jan 31, 2019 | 04:55 PM
andreigbs's Avatar
GLK 250
Happened to me as well, but only in really frigid temps when the car has sat overnight. Start it up and let it warm up at high idle (1500rpms) for a few minutes, then try Neutral first.
Old Jan 31, 2019 | 06:37 PM
Van Ha Nguyen's Avatar
2016 CLA 45, 2013 GLK 350
happened to me once too. Freaked me out. It was also very cold so I restarted the car and it worked again.
Old Jan 31, 2019 | 07:37 PM
HONDO250's Avatar
GLK250
SOLUTION TO Problem with not shifting into gear
I followed instruction from a Link on Youtube to re-program the Mercedes Computer to correct the problem. STEP BY STEP-It worked but hopefully, the problem will not reoccur.
Old Jan 31, 2019 | 07:42 PM
andreigbs's Avatar
GLK 250
I've seen several, none were too great. Would you mind sharing the link? Thanks in advance.
Old Feb 22, 2021 | 12:43 PM
rodfree1's Avatar
e350
please send me the link to reprogram the computor having the same problem thanks
Old Nov 23, 2021 | 01:26 PM
johny-rock's Avatar
2013 C63 AMG, 2010 GLK350
Had this exact problem this morning, any info or news on how to solve ?
Will call the dealer later in the day but maybe thta is an easy fix
Old Nov 24, 2021 | 07:14 PM
Mmr1's Avatar
2013 glk 350
How old is your oil.
Old Oct 23, 2023 | 11:27 AM
greyGLK250's Avatar
2013 GLK250
I encountered this same problem today in the cold morning, the transmission seems dead, no response to any shift. I figured that the transmission oil pressure is ok, no leaks; the electricity voltage is fine too because the engine started fine. It looks like a sensor cut off the electricity to transmission. I happened remove the trunk bottom cover in the morning, that cover is to cover the ad-blue refill. so I put the cover back and I can shift the transmission right after.
Old Nov 11, 2023 | 09:08 PM
greyGLK250's Avatar
2013 GLK250
I finally figured out why, the main battery needs to be replaced after 10 years. I bought a new AGM H7 battery and installed by myself, this problem has gone...
Old Nov 15, 2023 | 08:48 PM
m00nd0gy's Avatar
GLK350 ML55 Ducati Porsche
That happened in my ML55. I read the manual and it said stick a pen into shifter and press down. I was able to drive it home in safety mode no faster than 40 mph. The transmission solenoids need to replaced.
