Wind whistle blower motor
if it’s only while driving then i documented it with a fix in an earlier thread with pictures. Easy fix once you know that is the issue. All you need is duck tape to seal the deformed seal around the intake for the system. Right above the battery on the passenger side under the hood. Remove the cover and seal around it on the inside. Good luck. !
