Best Aftermarket HID brands to upgrade current Bi-Xenons
What are some recommendations in best brands to use for HID bulbs?
Top tier best units...
Philips 85415 - the absolute brightest bulb on the market. Not the absolute whitest though at 4800k.
Osram Xenarc CBB - the second brightest bulb on the market, but comes in at a crisp pure white for better aesthetics.
Let us know if we can further assist.
My ballasts were mounted on top of the fenders under the hood, ballasts don’t like heat and as original installations are mounted low at the bottom of the front fender . Mine fail to light in hot temps .
Don’t be a jerk, 8k blinds . Go under 5000k . Anz seems well knowledged.
Most manufacturers that equip their cars with HIDs will run 4300K systems, which is supposed to be the color/temp of "natural daylight," and that's what you want.
What bulb would you all recommend for the Fog lights?
They're not the LED strips their the round normal Halogens. I want to put a brighter bulb, possible LED bulbs without changing the whole light itself.
Also, want to change the Reverse lights to LED bulbs?
I run regular halogen bulbs (in my other car since GLK has LED strips) and I applied the yellow Lamin-X film. Cuts through fog and nighttime rainy weather very nicely. You could also run LEDs but beware you may get "bulb out" messages due to difference in wattage between halogens and LEDs.
