2010 GLK350 would not start
I have a 2010 GLK350 4matic and out of the blue it would not start. I pulled the front prefuse box and discovered there was some lack of continuity. Since I’m not an electrician, soldering a fuse back together is not an option. I was wondering what the parts with the arrows are called? Or if I completely replace the box, which part number goes with my vehicle.
A 204 540 39 50 or A 204 540 35 50. Thanks in advance for any help with this.
What’s the battery voltage ? I would think low voltage, or a bad connection off the battery or ground. Or corrosion. Or a bad battery . 12.5 -12.8 is a charged battery. Check voltage at battery and off the fuse panel.
