2013 GLK 350
Any advice or things to look for?
I'm just trying to flush out any known problems with the GLK. I know how that MB can be a money pit. I'm trying to avoid that.
But I'm not fan of new DFI engines. I would rather look for well taken care '10-'12 pre-face lift GLK with more miles (60-80k).
Side note...there was somebody here who had transmission replaced 2-3 times...that seems like a car issue and not transmission issue. Who knows.
Yes, intake is probably the last weak spot, but it's one time job.
Carbon build up on M276 is on the intake valves, just look at them when you do your spark plugs, which is a pita on M276.
But hey, your mileage is impressive, although highway miles are easy on the engine.
M276 just has more complexities for extra 20hp and 1-2mpg
Do you consider DI as an over complication? Yes it is I guess, however it’s obviously reliable and a Bosch hi-pressure fuel pump is only a $380 part so not the end of the world.
Both the M272 and the M276 are all aluminum, 4 valve, OHC, Variable valve timing, timing chains; what am I missing?
Oh yes the M276 does have *** (auto stop start) but guess what, this means it has an extremely robust oversized starter. But yes, that aspect is more complicated then the 272 I concede.
What other specific over-complications does the 276 have over the 272?
