Need help with a couple of fault codes
Old Feb 28, 2020 | 05:31 PM
Hwerrt's Avatar
2013 GLK250
Hi all
Been slowly fixing my '13GLK250.
Have a couple of fault codes that I just need some elaborating help.
• P0101: Mass or Volume Air Flow Sensor "A" Circuit Range/Performance - Mass or Volume Air Flow Sensor "A" Circuit Range/Performance
This one is this one that my CEL is on. I replaced a the drivers side IC hose (it split open), the passenger side IC hose still looks good. Now I have ordered a new Mass Air Flow sensor. Is there something else that I need to look at?
• P003F-FC: "A" Camshaft Profile Control Stuck On Bank 2 : Manufacturer Defined - "A" Camshaft Profile Control Stuck On Bank 2 : Manufacturer Defined
The schedule A oil change is coming in 21 days, could this code be dirty oil? Doing an oil change next week some time.
• B1797-15: Left standing light 2 has a malfunction. There is a short circuit to positive or an open circuit.
• B179B-15: Right standing light 2 has a malfunction. There is a short circuit to positive or an open circuit.
• B16BF-15: The left side-marker lamp has a malfunction. There is a short circuit to positive or an open circuit.
• B16C3-15: The right side-marker lamp has a malfunction. There is a short circuit to positive or an open circuit.
No idea where this is coming from, all my headlights, corners, turn brakes are all functioning. All lights are factory LEDs. What are the standing lights anyways?
• P062A-00: Check report for description. - Fuel Pump "A" Control Circuit Range/Performance : No Sub Type Information
Got me stumped totally on this one.
Any assistance would be greatly appreciated, Regards
Old Feb 28, 2020 | 06:34 PM
reesesboot's Avatar
2010 GLK 350 RWD
First off, where do you live and what's the mileage of the car?
MAF and fuel pump are most likely covered by your emissions warranty. Best to get into contact with your dealer regarding those. Has your battery ever been replaced? Sometimes electronics can get wonky in these if the battery is on its last leg. Best to test it if it's original. Not sure about the p003F-FC code..
In any case, if any of your items are covered under warranty, get it to a dealer, have them fix what's covered, and they'll do a comprehensive inspection on the car and let you know what the other issues are. You can then choose to take the car as-is and fix at your leisure.
Old Feb 28, 2020 | 07:05 PM
Hwerrt's Avatar
2013 GLK250
Hi, thanks for the reply,
I am in Edmonton Alberta Canada, and it has 96000kms (60,000miles)
​​​I am going to contact the stealership, bought it used from them
Regards
Old Feb 28, 2020 | 07:22 PM
reesesboot's Avatar
2010 GLK 350 RWD
I’m not familiar with the emissions warranty in Canada but your dealer should tell you. Keep us updated.
Old Feb 28, 2020 | 08:20 PM
Hwerrt's Avatar
2013 GLK250
According to the service warranty booklet, emissions is covered for 8years/130,000kms whichever comes first.
Don't know if the battery has been replaced. If it has, it was performed by the stealership that I bought it from, which happens to be the same one that sold it new to original owner
I will be confirming with stealership in the morning
Regards
Old Mar 1, 2020 | 12:27 PM
GLK Super Fan's Avatar
GLK250 ML350
Regards
If you live in Alberta and out of warranty, there are no reason for you to keep the emission bs. I will give Sam a Call @ECU program Calgary. He is probably one or the best tuner in Alberta when it comes to diesel Mercedes
Old Mar 1, 2020 | 12:38 PM
Hwerrt's Avatar
2013 GLK250
Can you please give me his number? I think that I will go down to Calgary and get it done,
Regards
Old Mar 1, 2020 | 03:50 PM
GLK250 ML350
Regards
403 891 3179. Let us know how it goes. Good luck
Old Dec 6, 2022 | 02:40 PM
zabbaskeema's Avatar
Glk 250 2013
And? :)
I have the same car and I got the P062A code as well as the B179B one!
Have you founs a way?
I also have the proximity sensor disabled problem but thats another story!
Cheers!
Pat
Hi all
