2015 GLK 350 Secret Engineering Mode Menu
Old Dec 5, 2020 | 04:11 PM
audiem's Avatar
2015 GLK 350
Unhappy 2015 GLK 350 Secret Engineering Mode Menu
I absolutely hate that I have to resort posting this, I have scoured the forums for the right key press to get into the Engineering Settings Mode so I can activate AUX seem to continue to strike out. 2015 GLK 350, I have a MMI and USB port in my glove box.
When I use red hangup + 1 + # for 10 seconds this is the menu I get. What is the other key press that I am missing?!
Old Dec 5, 2020 | 04:59 PM
Mmr1's Avatar
2013 glk 350
I think that’s it , your in the engineering menu, now have fun scrolling through each option to find what you need. Maybe YouTube has a video to direct you
Old Dec 7, 2020 | 09:10 PM
Travelness's Avatar
2010 GLK350 4Matic
Not sure if it makes any difference but what is the reason you need to activate AUX mode?
Old Dec 7, 2020 | 10:30 PM
audiem's Avatar
2015 GLK 350
Oh boy I’m such an idiot. I was looking for that 2 page engineering menu. Aux was already enabled and under the Audio menu rather than the media menu.
im doing a roadtop car play module + backup camera installation on my ‘15 GLK 350.
as of today I have everything functioning, last thing left is to figure out how to run the aux cable to center console where the mmi interface plug is.
Old Dec 9, 2020 | 02:18 PM
Flypenfly's Avatar
718 BGTS, ‘20 C63 Coupe
How hard it is to do an OEM backup camera install?
Old Dec 9, 2020 | 03:29 PM
audiem's Avatar
2015 GLK 350
Running the wires are the biggest pain point.
Actually found cameras that have a wireless dongle so you don’t have to run wire from the radio all the way to the back.
there is all kinds of YouTube videos of people and installers doing the back up camera.
I needed a camera interface module to make that possible so the road top CarPlay module just made sense.
what sucks about it, you need the MMI interface port for audio to function. Means running wire to the center console on my car. Means more crap you have to take a part to get the wire there cleanly.
saving myself $2k for pro install which is the cheapest I could find here.
Old May 4, 2021 | 06:41 PM
Dipen Neupane's Avatar
GLK 350
I just installed android screen in my GLK 2015 , everything works except AUX , it’s not getting activated...I have tried enabling through engineering mode but still not working,,,I can see the AUX option from drop down menu from Audio and when selecting AUX it doesn’t get highlighted..any solution for this ?
Old Jun 23, 2021 | 04:21 PM
HDMC ROB's Avatar
2015 GLA250
Did you figure this out or how to make it work? I have the exact same problem and the dealerships don't seem to have a clue how to help me.
Old Jul 6, 2021 | 06:06 PM
JONBOVI's Avatar
GLK 2014
I figured it all out guys I have the same X204 GLK with NO AMI port which has virtually no AUX but there is a solution it is late sorry for my bad bad english
1.) if your car has literary no AUX from OEM then you can "hack" it into the system using your new android device here is a video showing it ->
2.) once you activated your aux you have to tell the android system which AUX Position you use/have -> in the video 1:20
3.) and at last if you happen to have the super duper HARMAN KARDON Audio System then this might be the reason why you have no sound at all!!! Sinde HK uses optical sound wires which are not included in the china adapter you have to carefully put them out of the original harness and put them into the china one -> see here https://www.realmediashop.de/DOKU/TX...CKGUIDE_EN.pdf
the 1 & 2 were hard to find but the harman kardon optical wire thing..... I browsed the whole internet for that info
would be nice if @admin would mark this thread as (SOLVED) since a lot of people have this problem and are desperate looking for info on youtube and so on
Old Jul 6, 2021 | 06:07 PM
JONBOVI's Avatar
GLK 2014
