CarPlay adapter works great but won't fit inside my 2014GLK.
I got everything connected, and everything looks good, everything functions as it should, but when I tried to put it all back together, it's just not possible. Not only is there no room for the device, which is pretty small and thin, but there's no room for the wiring harnesses. which is a lot bulkier.
Has any one done one of these upgrade? and if so, where did you put all the cables
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Here are my recommendations.
the device itself can be wedge in the dead space between the center vent and screen.
as for the wiring harness i wrestled it for more than 2 hours both times before I can get the radio to sit back and even the. It was a tight fit. The problem is the extra volume the plug n play harness takes up so you really have two options:
1) cut the old harness from the original plug and cut the end of the aftermarket harness. Splice the wires accordingly to conserve space
2) with the climate control module removed, stick your hand in the slot and from underneath the radio slot, begin to tug the radio harness into the climate control slot
https://mbworld.org/forums/glk-class...olink-box.html
