GLK radio issues
GLK radio issues
Good morning
Having issues with a GLK radio. When I first get in the truck and turn the radio on, all is fine. However, after stopping and turning off the engine, when I return and turn the radio on I hear a thumping noise from what seems to be each speaker sequentially. Also, when I try to tune the radio, the dial just speeds through every frequency and stops at the one it was on. There is no radio/CD/phone/XM at this time. Sometimes after driving for a while, it comes back, usually after at least a half-hour. This issue seems to occur more frequently on warm days when the truck is outside in the heat/sun. Two quick videos attached, one of the sound, one of the tuning.
Does anyone have any idea what causes this? Is the radio receiver going, or is it the amplifier? If I were to go the route of a new radio, are they coded to the specific vehicle?
Thanks in advance.
Thanks in advance.
100Pyatt (02-12-2024)
Thanks for the tip. Replaced the unit, new one works on startup but will have to wait to see if issue materializes again.
Now however, the backup camera does not come on when put in reverse. The display simply stays on the radio. Does the unit have to be reprogrammed?
I came here with a very similar issue with the radio speakers popping on the wifes 2011 GLK350 . It is very consistant with how it operates or doesn't . The first time you turn the radio on after starting the car (for the first time of the day) the radio will operate fine . There are no signs of a bad speaker or amplifier etc , it works perfectly until you either turn the radio off or switch the car off . It will then click and pop all the speakers and you can not navigate the menu while it is doing this . The backup camera will work but the popping continues . The unit will not operate for the rest of the day . Next day repeat . If we turn the radio on after the 1st start of the day it will continue to operate fine even if we drive 300 miles , but as soon as we turn it or the car off it will start popping again and is finished for the day .
I was going to buy a used head unit off of Ebay until I read that it had to be programmed by the dealer to match the VIN . The dealer says they would just have to get it in for troubleshooting as it could be one of several modules and would not give a price to troubleshoot . We could live without the radio but using the backup camera is a headache with the speakers popping the whole time .
I thought some here may have ran into the same issue . Yours sounds very similar .
I bought a radio on ebay, making sure the VIN number identified a similar radio (I ended up with a single CD, had the changer) and making sure the unit was compatible. It seems that the 2010 isn't compatible with the 2011 and later ones have a slightly different roundedness to the faceplate.
I was concerned with coding it to my vehicle, but it worked right from the get-go. The only issue was the camera, which didn't work initially. However, after driving it, I realized that it now works. Perhaps driving it reset it. No dealer programming required.
If you want to do it yourself, this youtube video was fantastic. It really was one of the easiest jobs I've done and was done in under an hour.
Let us know how it turns out
andreigbs (09-27-2021)
Seems like it needed to reset itself.
Exact same vehicle, exact same problem. However, we would eventually get the radio back at some point during an hour drive, if the unit was turned off. It seemed like the heat made the problem worse.
https://www.youtube.com/watch?v=cYyW-VFVTQY
I had watched that video a few weeks ago and as I owned a accessory shop for 20 years that did quite a few stereo installs , I still have all the specialized tools to take it all apart . I had put it on the back burner after reading that a dealer would still need to re-program a used unit . I think I'll look around Ebay again and give a used head unit a shot . I guess all I would be out is a couple hundred bucks , a couple hours and a few beers . Best case is it works and the wife is happy with her car again
Thanks a bunch
https://www.ebay.com/itm/27224335148...cAAOxycD9TV-5I
"THIS SYSTEM IS UNLOCKED. BUT, SOME MODEL STILL NEED PROGRAMMING AT DEALER TO MAKE WORK INSTRUMENT CLUSTER WORK WITH NAV SYSTEM. THIS AUCTION ONLY NAV COMAND HEAD UNIT ONLY !! NO MONITOR OR OTHER PARTS FOR SALE!RIGHT NOW SYSTEM HAS BEEN PROGRAMMED WITH
- HDD USA NAVIGATION - YES
- HARMON KARDON SPEAKER SOUND - YES
- 6DISC CD CHANGER - YES
- BLUETOOTH - YES
- UCI MEDIA INTERFACE - NO
- SATELLITE RADIO - NO
- AUX - YES
- BACKUP CAMERA - NO
- WE CAN PROGRAM RADIO TO MATCH UP WITH YOUR VIN NUMBER OPTION AS WELL $150 EXTRA )"
Sounds problems
Hi everyone. I experience the same problem with the sound. In the morning when I start everything works well and if I stop the engine and turn it back on the sounds is gone and the speakers popping. So you said that changing the radio unit worked. A heard someone that it could be the amplifier. I don't know what to try and replace first. Thank you in advance.
I too just bought a "new" radio head unit (aka control unit) from eBay. Same exact part number (THAT was hard to find!), and like others have said, the eBay vendor (a very, very large vendor) suggested that I may need to contact MB with the donor vehicle VIN or the radio serial number. It sounds like (hopefully) that may not be necessary.
I did find a free code generator app, but it doesn't recognize the radio serial number.
I'm OK with just trying to swap the head unit (looks like an easy enough job) but it would be great to get a second opinion - will I need to contact MB to get a code or not?
Just to close out the issue - the NTG 4.0 radio indeed does NOT require a code to install a new radio (or reboot the original radio after disconnecting the battery, etc.). Kind of refreshing, though I did spend a fair amount of time trying to chase down the info.
I'll be doing a "radio ID, procurement and installation" video in the next few weeks.
Roadrashed (01-25-2024)
