Dealer overfilled GLK250 Engine Oil. Need advice
My wife bought a GLK250 soon to be 2 years ago. Always had it serviced at the dealer. And by always I really mean the two times she changed oil. This time I decided that I can do it after having done it on my GL a couple times.
I bought the kit from ID parts with filter and 7L of oil. What I normally do, is fill up all but one liter, then drain the old oil from the catcher into the freshly emptied containers as a sanity check to make sure it is roughly same amount as I am putting in. Plus to see if any oil is burning/leaking somewhere.
This time after having filled it up with 6L, the catcher still had quite a bit of oil. I emptied the last bottle - about half of it went into engine, half went to a another half empty bottle left from GL (same oil). Filled the last, 7th liter out of the catcher, then emptied the rest into a 4 liter jug. Guys, there was 2+ liters that went into the jug. So overall, something like 9+ liters have been drained from her engine which should be shy of 7. Dipstick is midrange with the 6.5 that I put in.
Looked around the engine bay, sure enough there is oil coverage all over. When I pulled down the undercarriage shield I noticed the bottom was in oil gunk, but didn't think much of it, perhaps a previous repair. Now I'm very angry and very worried. I know that some came up at the oil fill - there is oil all over that. But I do not know how it got everywhere else... Now I'm thinking maybe too much oil can cause things like head gasket to blow? She did get low on coolant twice this year which concerned me. But dealer told me not to worry.
Do I have any recourse? I can take the oil in and show them, show the engine bay, show that they did the last change. But they can say that since they didn't drain the oil I cannot prove that they did this?
I'm sooo upset! I was too scared to touch someone else car, even my wife's, that is why I only ever did work on my own. I told her that she best just take it in for service, that she would pay more but have peace of mind. And it turns out that it's the opposite. That these morons could well have sentenced the engine.
has anyone ever had this type of situation? Any advice?
I’ve never overfilled a car but from what I’ve read oil pressure increases and makes seals leak, it also rides up into the cilinder and burns. My question, how can you not ever check your oil level in a year? That in itself is asking for trouble. Like if you had a head gasket leak you would never know. How many miles is on the oil?
I thought of doing that. But that seems like just getting them to tell me to pound sand but with extra steps? You think there is any chance they would help in that case?
I think put back in the overfilled old oil, go to the dealer, complain knowing there will probably no full resolution, then contact mb corporate and file a complaint.
They caused any leaks you now have. It was higher a year ago.
Complain to BBB, that can push them along, threaten allot of bad reviews, companies don’t like bad reviews.
I don't think showing or telling them is going to solve anything. I would just clean up the exterior as well as you can, make sure the oil is at correct level and NEVER go to the stealer for anything that you can do yourself or pay a good Indy HALF to do a better job.
If you really want to lose sleep, worry about whether those monkeys even used the correct 229.51 or 229.52 oil for your OM651 engine! Chances are quite high they just dump whatever bulk oil they put in everything else, not even bothering to check it afterward...
The bottom engine cover can be degreased and pressure washed, then I'd clean the engine itself carefully and inspect periodically for leaks.
And check the coolant level as karmikan suggested. Hopefully there are no gaskets gone south.
)I typically stop adding when the oil dipstick shows 2/3, not a MAX mark on a WARM engine after an oil change. On a cold engine, it most likely will show up as overfilled but not with 9L+ of oil like OP mentioned .... With this much oil, it would probably start coming out of PCV breather on top of the valve cover after a few trips...
