722.96 Transmission Communication
Old Feb 1, 2022 | 11:34 PM
Shrumsjs's Avatar
2015 GLK350 108k miles2008 clk350 Cab 180k miles. 1998 E300TD 237k miles
2015 MB GLK350 with 722.96 Transmission occasionally get warning message “service needed, do not change gears, see dealer” then messages goes away and all is good. No check engine light. Usually occurs when initially starting engine but it always. Have scanned and here is list of codes. Appears to be communication problem. Any help appreciated.
Last edited by Shrumsjs; Feb 4, 2022 at 05:55 PM. Reason: New code image after clearing codes
Old Feb 2, 2022 | 10:40 AM
andreigbs's Avatar
GLK 250
Could be a loose wire or connection, or some internal fault in the TCU.
Or weak battery, who knows? How is the shifting otherwise? Has the fluid & filter ever been changed?
Old Feb 2, 2022 | 11:36 AM
Shrumsjs's Avatar
transmission serviced at 80k miles currently 108k miles. No noticeable issues shifting.
Old Feb 2, 2022 | 11:39 AM
Shrumsjs's Avatar
Rebuilt TCU
anyone have experience with companies that rebuild/repair TCU. I see several in the web?
Old Feb 2, 2022 | 12:01 PM
KTM530's Avatar
GLK250
Take a look to this video, there is some similarity with your code.
Old Feb 16, 2022 | 01:46 PM
Shrumsjs's Avatar
Update:
Took GLK350 to dealer today. cleared codes and reset computers (?) but could not find problem. Service tech said to just drive it and see if the warning comes back. Said they did not do indepth check as "I was waiting". Went to crank the car and warning flashed again. So another appointment to do "indepth" analysis. and another $170.
Old Feb 16, 2022 | 02:01 PM
glkoffroad's Avatar
glk
keep us posted with the fix
Old Feb 16, 2022 | 02:22 PM
Mmr1's Avatar
2013 glk 350
How old is the main battery ? If old get it tested
Old Feb 16, 2022 | 04:16 PM
dzl_benz's Avatar
2015 GLK 250 BlueTec with AMG Sport package.
... with that many communication codes, it's either a battery or oxidized ground points. If it's 2015 - most likely the original battery. I'd get that replaced sooner rather than later. I haven't had exact same issue with my 2015 GLK just yet but the OEM Varta battery is stamped 11/12 so 10 years almost.
My 2001 SLK gave me about the same laundry list of codes after one particularly cold morning start. Tested the battery and it was showing 12.1V without any load just on its own. Charged battery, cleared codes, drove for a week - not a single code came back but kept an eye on battery voltage. Also did a load test and yes - it's time to replace it. If these cars were sensitive 20 years ago they'd be even more so now.
Old Feb 17, 2022 | 04:06 PM
Shrumsjs's Avatar
Battery ok
Did load test and main battery ok. Not original battery. Both batteries have been replaced but do not know age
