Keyfob wont unlock... sometimes
Old May 24, 2022 | 12:28 PM
jc702's Avatar
GLK 350
Hello all, great forum have learned a lot of DIY from here so thank you.
Now my keyfob wont work if the car has been sitting for over 7 hours. None of the buttons will work, besides using the physical key to get in if i try to open the truck then i can unlock the car.
Or when i use the physical key to get it, then the keyfob starts to work again.
Yes my keyfob will work only after opening the truck. I have changed the keyfob battery to no avail.
The battery doesnt drain or anything.
The keyfob just stops communicating.
Would it be a keyfob programming issue? or would i need the security system diagnosed?
i was thinking of just getting an aftermarket alarm to unlock the vehicle.
Thanks in advance
Old May 24, 2022 | 02:09 PM
Mmr1's Avatar
2013 glk 350
Test the main battery after sitting at least 7 hours is it an AGM battery ? If not check for corrosion on terminals. It could be a loose or corroded wire or terminal
Old May 24, 2022 | 02:43 PM
jc702's Avatar
GLK 350
Gonne be honest and say I havent tested the battery. Since it would start up and never had issues I assumed the battery was fine.
I will check/ test and report back
Old May 24, 2022 | 03:03 PM
Mmr1's Avatar
2013 glk 350
If voltage is below 12.3-12.4 it could be the battery . A 12v battery is actually near dead at 12v. Your alternator charges them when running to 13.25-13.6 or so. A corroded connection or bad ground could be contributing. If it’s weak get it load tested, any auto store does it free, so they can sell you a battery!
Old May 24, 2022 | 10:07 PM
jc702's Avatar
GLK 350
The battery is at 12.3 volts after unlocking it from the truck. I suspect it may be a lower voltage prior to unlocking. I will see after sitting over night.
the battery is a Bosch agm battery, not sure how old it is at least 30 months old by now
Old May 25, 2022 | 05:56 PM
jc702's Avatar
GLK 350
I tested the battery this morning, left the hood unlatched so i can test it after sitting unused overnight, at it read at 12.28v
Old May 25, 2022 | 06:59 PM
Mmr1's Avatar
2013 glk 350
Thats ok, since it turns over the motor it is. I have no idea, maybe corrosion on the key fob battery terminals . A new fob key might help. There are a few other groups in mb world that know more than me , I’m just guessing.
Old May 26, 2022 | 08:15 AM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Agreed: if the battery can start the engine then it's not the problem.
Do you have another fob? Does it act the same way?
When you say "my keyfob will work only after opening the truck" do you mean "trunk" (tailgate)? If so, do you open it with the fob or the key?
Does anything happen if you press the "lock" button first?
Does your car have an auxiliary battery? Is it in good condition? I'm wondering if the car looses track of the current rolling code after 7 hours.
