Major engine issues
- P0299 - Turbocharger/Supercharger Underboost
- P0171 - System Too Lean Bank 1
- P056E - Cold Star Turbocharger/Supercharger Boost Control 'A'
- P244B - Diesel Particulate Filter Differential Pressure Too High Bank 1
Would love to hear your thoughts on this. Reading up on those error codes, seems like this is going to be expensive as hell to fix.
If not, easy one hour job to do. From under the car, remove the front shield and you will get access to the hose. Two flat screw driver is needed to unlock each clips and your done. Doing so check for the metal frame part that is rubbing and digging an hole that might be the cause of your problem. Cut mine with a metal saw blade.
FYI, the dealership techs are supposed to follow specific protocols of diagnosis depending on the fault code(s) present, and from my personal experience, they NEVER even touched the intercooler boost hose in question. Instead, they tested the wastegate controller and replaced that (for free, because it didn't fix anything, and because it was after the AEM work had been performed, so pretty much everything is now covered).
I knew it was the boost pipe and even told them to check it. Made 2 separate trips to the dealer after they "fixed it" only to have the same code pop up on the way home (I live 45 min from the closest MB dealer).
Once home, I crawled underneath and disconnected the hose, found not one, but 2 separate tears in it. Wrapped it in electrical tape to hold me over until the new arrived. $120 and 30 minutes of my time instead of multiple aggravated visits to the dealership.
FYI #2: techs hate being told what the problem is, especially by owners who typically don't know much. But press your point repeatedly: check the driver's side intercooler boost hose. Don't just visually look at it, disconnect it, handle it, turn it over, squeeze it here and there and you will see at least one tear in it.
Good luck.
Andreigbs, you're so them right in your last post...once again.
