GLK brake upgrade
Old Jul 7, 2022 | 02:33 PM
mercedesbenzglk's Avatar
glk350
GLK brake upgrade
Hey all,
I recently bought a 2015 GLK 350 with low miles, (23,000).
Obviously one of the first things I noticed was the notorious brake dust that these give off, so with a little research I came across people doing Akebono ceramic pads for both front and rear. I did read a few conflicting reviews but I thought what the hell, I'll try them.
Along with the ceramic pads I also went with Zimmermann rotors, this combo is absolutely awesome! very little brake dust and stops just as well as the originals. I was able to compare between the factory and aftermarket as my mother in law has the same 2015 GLK 350 so I drove one right after the other. highly recommend!!!
Old Jul 7, 2022 | 02:54 PM
Mmr1's Avatar
2013 glk 350
I have Zimmerman Rotors also.
Your test was with one vehicle with new rotors and new pads, against one with old rotors and old pads? How can that be a fair test?
Old Jul 7, 2022 | 04:32 PM
glk350
The other GLK had new OEM rotors and pads installed as well, roughly 600 miles since replaced
Old Jul 7, 2022 | 05:29 PM
Mmr1's Avatar
2013 glk 350
Zimmerman rotors work well. New Brake fluid makes a big difference in stopping power. With Age and miles it degrades from moisture.
Old Jul 8, 2022 | 06:55 AM
NYCGLK's Avatar
GLK 350 / Porsche 993
MB pads are junk.
Old Jul 8, 2022 | 06:56 AM
NYCGLK's Avatar
It's supposed to be flushed every couple of years so it should never really get that old.
Old Jul 8, 2022 | 07:40 AM
Mmr1's Avatar
2013 glk 350
Sure, how many people flush brake fluid?
Old Jul 10, 2022 | 12:06 PM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Originally Posted by NYCGLK
MB pads are junk.
you know what opinions are like.... Any back up to your story?
Old Jul 10, 2022 | 01:21 PM
NYCGLK's Avatar
yes opinions are like *******s...
The mb pads leave terrible pad deposits causing constant rotor replacement and/or rotor warping.
Old Jul 10, 2022 | 02:19 PM
insame1's Avatar
Pad deposits don't cause rotor warping. a few good high speed stops will clear that right up. they are very dusty but to say they are crap is a bit much. The good thing about them is they are paired. Rotors and pads should be paired or you are likely going to shorten the life of one or the other.
Old Jul 11, 2022 | 06:49 AM
Znwiefel's Avatar
2011 Glk350
Bedding the pads to the rotors after a replacement is an important step that quite a few mechanics forget or neglect to do due to the extra time it takes. I work at a semi-luxury vehicle brand and I see more people coming in with unevenly worn pads and rotors because this step was overlooked.
Old Jul 11, 2022 | 08:00 AM
MBKLUE's Avatar
Yikes:
Does this apply only to new rotors with new pads? (vs. new pads with older rotors)
Old Jul 11, 2022 | 11:31 AM
RussBarnes's Avatar
2015 Mercedes Benz GLK350
First repair after purchase.
Bought my used, one owner, 52k mile GLK350 from MB dealer that originally sold and serviced it. My mistake believing that when the salesperson said it was in excellent condition and had been completely tested. Flew to Scottsdale, picked up car, drove to hotel and could tell it had warped rotors. Got home after 1,700mi and immediately went to R1 and ordered four new drilled rotors and ceramic pads. Changed parts, DOT 4 fluid and broke in per typical recommendation. They work great, stop on a dime with change left over . Cost about $500 vs MB cost at least 5x higher and installing proven inferior parts.
Old Jul 11, 2022 | 11:41 AM
NYCGLK's Avatar
Unfortunately quick few stops just made matters worse. It seemed that set of rotors was warped (after 16k miles). Next set started vibrating after 6k miles getting worse. I went with aftermarket mads and drilled rotos this time. Let's see how this goes.
And yes I bed the pads in.
Old Jul 11, 2022 | 12:30 PM
insame1's Avatar
https://www.crossdrilledrotors.ca/blog/part-one-rotors-dont-warp#:~:text=Brake%20rotors%20do%20not%20warp,out% 2Dof%2Dtrue%20rotor.
Facts.
Brake rotors don't warp they ware unevenly.
drilled rotors are no longer necessary and are primarily for looks.
ceramic pads are great for dust but are not as effective on a street car as a semi metallic pad.
brake fluid should be change every 2 years.
Old Jul 11, 2022 | 12:58 PM
NYCGLK's Avatar
Facts.
Possible but I only used new rotors and always torque wheels in star pattern. One set was so deformed that you could feel it by spinning the wheel - this was after 15k miles. Most resent felt fine, but would vibrate when braking from hi speeds that was after 6k miles. Pads looked very good actually...smooth and even.
Agree that cross drilled rotors are not necessary but I wanted to try something different. Id like slotted rotors.
Old Jul 11, 2022 | 01:18 PM
insame1's Avatar
Not saying you were wrong more of a recap for the thread. I change my rotors and pads together every time also.
Old Jul 11, 2022 | 04:01 PM
Znwiefel's Avatar
2011 Glk350
In my personal opinion, I have never been a fan of pad slapping a car. If I can I try to replace the rotors along with the pads or at least turn the rotors. Then proceed with the bedding process to get the most stopping power out of your brakes.
Old Jul 11, 2022 | 10:50 PM
NYCGLK's Avatar
Now you are getting technical...In theory yes you want to transfer pad material to the rotor - purpose of bedding pads in. But who in this day and age changes pads without changing rotors? When my original brakes were ready for replacement, the rotors were so grooved there is no way they could be re-used plus they are so cheap (or free) I'm not sure why would anybody go through trouble of changing pads and leave old rotors on a street car. On a race car, that's a different story.
Old Jul 12, 2022 | 12:14 AM
MBKLUE's Avatar
Yikes:
I'm sure there are people that don't change rotors every time they change pads. Not dealerships though, I'm sure. Obviously, if the rotors are in bad shape, it would be wise to change all. I'm still on my original rotors and pads with my 2014 GLK. No grooving, no vibration, no pulsating. I have new pads and rotors "on standby" in my garage.
Heck, there are people that don't change the oil filter with every oil change. That one seems like false economy to me.
Old Jul 12, 2022 | 06:35 AM
NYCGLK's Avatar
At some point you want to see the other side of the rotor...that's what gets nasty looking. You will feel at some point under heavy braking.
Old Jul 12, 2022 | 08:46 AM
MBKLUE's Avatar
Yikes:
There's no reason for the inner part of rotor to be worse than the outside unless you're driving on gravel or something like that and pieces get stuck between the rotor and the brake shield. If that happens you're probably going hear some ugly things pretty quickly.
I swap wheels/tires twice a year and change brake fluid once every two years (with the wheels off) so I inspect the brakes fairly regularly while I'm at it. Not as easy on the inside of the rotor with the shield but you can get a bit of a look. A lot of these problems have to do with how people drive/brake, using harder brake pads, the surfaces/roads they drive on, average ambient temp and salt/gravel content on the roads in winter - depending on where they live.
I don't do much heavy braking but when I do I don't keep the pads clamped to the rotors for an extended period (great way to transfer pad material to the rotors). I release the brakes lightly and creep forward.
Old Jul 12, 2022 | 08:56 AM
NYCGLK's Avatar
I am just sharing my experience with GLK that I have had for 13 years and 118k miles at this point while doing most of the work myself. It was night and day difference. Your results may vary
Old Jul 12, 2022 | 10:14 AM
MBKLUE's Avatar
Yikes:
Understood. I've had mine since new almost 10 years ago. Drive it on the autobahn every day. Only had Mercedes do the very first service and have done everything else myself. Also do my own work on my other cars.
My GLK still has the original main battery and rear hatch struts which seem like new. Some folks seem to have issues with those. Having said that, I bought a new main battery recently and new rear struts so I'm ready when the time comes. They can't last THAT much longer... I assume.
Old Jul 12, 2022 | 02:12 PM
insame1's Avatar
It sounds like you keep up on your car but with a floating caliper the force starts on the inside of the rotor and then is applied to the other pad by the fixed part of the caliper. It is quite likely that the inside of the rotor will have more wear then the outside.
