Frt. Strut Replacement & What Else?
my mechanic wanted like 1/3 of what the mb dealer wanted for suspension parts , 5000.00, vs 1500. I went to FCP euro and my mechanic did it for a few hundred. The point is . Parts are parts , a few hours to put on. FCP has a life time warranty and check around for instal prices . MB is the biggest Rip off !
https://www.mbdirectparts.com/v-2010...and-components
The ball bearing & the top strut mount are shown separately which from my experience on other vehicles is usually combined. The dust shield & the upper & lower mounts are possibly rubber which can deteriorate with age so to replace them is a toss up. The cost is minimal so why not. The nut is a one time use item so its replacement is a no brainer. Another repair while the suspension is apart is to replace what the dealership calls a thrust rod bushings which is actually the lower control arm bushing. One has started to fail so it goes on the list. Anything else? TIA!
You can check their state by jacking up the front wheels off the ground and trying to wiggle the wheels. If there is any play, it's the tie rods (not the wheel bearings, which would make an awful noise if they were bad).
@Mmr1, I will refrain from providing you with a good laugh by not disclosing what the dealership quoted me for the replacement of the "thrust rod bushing" which is actually the upper control arm inner bushing. It is a press fit bushing which is not difficult to install once the arm is removed. Before It goes into the shop, which will be at least a year away, I will do a thorough check over of the mentioned suspension pieces after which a new "realistic" estimate of repairs will be created.
One of my criticisms about this particular dealership which is only one of many dealerships owned by a large corporation is that no discounts are given for parts if you are a member of the MB club. BMW does it & back in the day of driving Saabs, I was given a discount not only on parts purchased at the counter but also on parts needed for repairs. My how the world continues to change & not always for the better.
