Which tires wear faster ? front or rear?
Old Feb 17, 2023 | 07:05 AM
mdspawn's Avatar
Mercedes GLK
Question Which tires wear faster ? front or rear?
Hello guys! I searched all forums but found conflicting opinions regarding tyre wear. So which tyres wear faster on a GLK 250 4matic, front or rear?
Old Feb 17, 2023 | 07:18 AM
Mmr1's Avatar
2013 glk 350
Front brakes and tires have more load on them turning and braking. Front brakes might take 60-75% of the load.
Old Feb 17, 2023 | 08:28 AM
Silver Shadow's Avatar
2006 Alfa Romeo Brera, 2010 GLK350, 2018 BMW 640i GT, 1997 Subaru SVX, 2012 Moto Guzzi Norge GT8V
The 4matic system is slightly rear biased. In normal driving more drive is going to the rear tires. I would expect the front and rear to wear quite evenly unless you have a heavy foot on the gas pedal. Typically in North America where we drive on the right side of the road, the right front tire will wear the quickest. The car travels further turning left at intersections and loads the right front tire. Also,where possible, roads are designed with longer left hand curves. The opposite is true in the UK, Australia etc.
Old Feb 17, 2023 | 10:27 AM
andreigbs's Avatar
GLK 250
If you rotate and balance as you're supposed to, they should wear evenly.
Question: are you rotating the tires on a schedule? If not, start there.
Old Feb 17, 2023 | 12:31 PM
GLKattitude's Avatar
2013 GLK 350
Sorry, but where on earth did you come up with all this “turning left/longer left hand curves” stuff? Do you commute on a nascar track? I hope no one reads this and believes it.
Old Feb 17, 2023 | 12:47 PM
The King of Trolls strikes again!!!
Do some research.
Old Feb 17, 2023 | 12:49 PM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
I, for one, try to avoid turning left whenever possible because I don't like crossing in front of oncoming traffic. Which tires should I expect to wear faster?
But, if they wear evenly, then there's no need to rotate them, right?
Old Feb 17, 2023 | 12:52 PM
habbyguy's Avatar
2011 GLK 350 4Matic
Well, theoretically the radius of a left turn / curve IS longer when driving on the right since you're one or two lanes further toward the outside of the radius... but the difference would have to be in the 0.0001% of total miles driven range (unless all your miles are in dense urban conditions, in which case it might be as high as 0.001%). ;-)
I'd have to think that the effect of the crown built into (almost) every road would have a much bigger effect on the tire wear (since essentially, your car is kind of "crabbing" to the left to stay straight on a crowned road. Again, the effect has to be pretty minimal, but WAY bigger than any difference in the radius of left and right turns / curves!
Old Feb 17, 2023 | 01:00 PM
2013 GLK 350
Do some research.
OH! So you’re one of those who just screams “Troll!!” When someone disagrees with you huh? Got it. I’ve been looking it up for 15 min and can find Nothing that says “roads in NA have longer left hand curves.” I Want my 15 min back..
Old Feb 17, 2023 | 01:26 PM
andreigbs's Avatar
GLK 250
My statement was conditional: if A, then B.
In general when considering tire wear, there are many variables involved among which are weight distribution, tire pressure, tire compound, drivetrain (FWD vs RWD vs AWD vs 4x4, etc.), alignment, braking patterns, speed, miles run, steering axle (front only, rear added?) turning aggression and probably a few others I'm forgetting.
Since it's probably too complicated to weigh each of these variables against each other or combinations thereof to see which ones are causing uneven more tire wear, both auto and tire mfr's (as well as tire shops who sell/install/service them) have rotation and balancing schedules in place to help keep it simple. I say stick to that schedule or as close to it as possible. The only caveat is if you're running a staggered setup.
Last edited by andreigbs; Feb 17, 2023 at 05:25 PM. Reason: Fixed to make John CC happy :)
Old Feb 17, 2023 | 01:52 PM
John CC's Avatar
So if they need to be rotated, then they must wear unevenly, so OP's question is valid, and remains unanswered!
You can even out the wear, but you can't make then wear evenly!
Old Feb 17, 2023 | 05:22 PM
andreigbs's Avatar
GLK 250
I believe the OP's question (and title of this thread) is "which tires wear faster? front or rear?" not "do tires wear evenly?"
That's what I was trying to answer anyway... I guess the best answer would be "it depends."
Old Feb 17, 2023 | 08:51 PM
This explains in detail what I was talking about above. There is a lot of extra information concerning guard rails and other obstructions. The basic premise in highway design is SSD, stopping sight distance.
https://etrr.springeropen.com/articl...544-016-0208-6
Old Feb 17, 2023 | 09:32 PM
John CC's Avatar
Maybe the better question would have been "Do tires wear faster on the front or on the back?
Old Feb 17, 2023 | 11:22 PM
2013 GLK 350
Very in the weeds article but a good read. Yes it speaks almost entirely about SSD, basically building roads where drivers can see around the curves effectively enough to stop in time. I must have missed the “road builders make left hand curves longer than right hand curves” or whatever.
Front tires will wear more than rear tires on account of castor/camber effects/changes and constant Scrub Radius changes (Not to mention F alignment is often more difficult to achieve and maintain than R alignment). This is the Entire reason for tire rotations, to “share the love” among all tires so a person can buy them in sets instead of pairs like white trash..
Old Feb 18, 2023 | 12:35 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
Here is a tangent that ought to get some opinions:
If the car/SUV is driven hard enough for the stability system to see evidence of impending oversteer (i.e., rear end swinging out), it will apply the inside rear wheel brake to pull the rear end back in. Since right hand corners are sharper than left hand ones, the right brake will be used harder and more often. This will result in more wear on the right rear tire.
But then again, none of us are hitting corners hard in our little square K boxes, trying to keep up with the 911s. Are we?
Old Feb 18, 2023 | 05:32 AM
mdspawn's Avatar
Mercedes GLK
Thank you all for answering. I had a set of wheels (235/65 R17) with uneven wear, and I installed the better pair on the front.
Old Feb 18, 2023 | 08:29 AM
John CC's Avatar
ALWAYS install the better pair on the rear! If you don't you may suddenly find yourself looking back at where you just came from.
Old Feb 18, 2023 | 11:43 AM
NYCGLK's Avatar
GLK 350 / Porsche 993
front tires do more turning and scrubbing and wear faster. No rocket science here.
RWD bias is a bit of non-sense. There is a hard connection to the front wheels and clutches for the rear so it's really a FWD car with some power going to the back especially when needed.
Old Feb 18, 2023 | 11:47 AM
NYCGLK's Avatar
ehh I now what you mean, but can make the same argument for putting better tires on the front wheels that steer and hit big puddles first.
Old Feb 18, 2023 | 12:05 PM
RussBarnes's Avatar
2015 Mercedes Benz GLK350
Unless You Drive A Base
My '15 GLK350 Base had four new tires put on sometime in the past. I don't know the service history, but when I picked it up it was obvious that the tires hadn't been rotated. In the year I have driven it (Approx 8,000 miles) I admit I have pressed the "S" button at traffic lights many times to show millennials in their Rice Rockets or loud pickups that an old man in a Benz isn't necessarily slow. And the rears do spin, squeel and if wet, pull a little to the side. But I am doing this for fun and because the fronts still look new. I want more wear on the rears to just buy a pair and then begin a rotation schedule.
Just another opinion about tire wear.
Old Feb 18, 2023 | 05:08 PM
John CC's Avatar
Not so! If the rear tires loose traction from too much torque, braking, or turning forces, the car tends to switch ends (oversteer). If the front tires loose traction it tends to go straight (understeer). Most drivers can handle a little understeer. Most can't handle any oversteer.
Old Feb 18, 2023 | 09:57 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
So which tyres wear faster front or rear?
....the whole equation changes when you add adjustability !
Background is ex factory there is only Toe “directional” adjustment. New car industry’s best kept secret. All to do with cost cutting and ever increasing speed of new car assembly lines.
There is no longer front or rear Camber (or Caster) allowing to adjust tire contact angles - spread load more evenly to resolve costly, premature, excessive edge wear.
Encountered in day to day commuting - high cambered roads with excess passenger side edge wear. Wheel squat through load carrying or lowering. Fitting wide profile tires. Or just having once again as per the 90’s - ongoing adjustability for curb knocks.
We saw the need and manufacture both Front and Rear adjustment to fix it right the 1st time.
Spoiler
AUDI to VOLVO - K-MAC Experience Of Resolving OEM Suspension Shortcomings Since 1964 !
Old Feb 19, 2023 | 12:04 PM
NYCGLK's Avatar
that's what ESP is for.
Old Feb 19, 2023 | 12:49 PM
Mmr1's Avatar
2013 glk 350
Putting new tires on the rear was always correct. But now today with antilock brakes , AWD, and Stability systems , that should negate most of the reasons for this. New tires on front won’t hydroplane as quick , stop better and handle more snow. So what is best?
