weird hissing noise and diesel smell in engine compartment
Old Mar 4, 2023 | 02:20 AM
slmskrs's Avatar
2013 GLK250, 2022 Tesla MYLR, 1997 Correct Craft Ski Nautique
We've started hearing a hissing sound, and we've been smelling diesel from the engine compartment. I thought it might be a blown intercooler hose based on the sound (but that wouldn't explain the smell, plus no error codes). I took all the bottom covers off looking for a hole or lose fitting on the exhaust lines, but nothing. The hissing is most noticable as RPMs drop although when driving, I hear it when accelerating as well as slowing down. It almost sounds like a sucking sound, but since there is diesel fumes, I think it is pressure instead.
Started the car with the top cover off, and rather than hearing the hissing on the right side where the exhaust manifold, etc. is, the hissing sound is coming from the left side. Here's a youtube video I did of it. You can kind of hear it when RPMs go up, but definitely as the RPMs drop. In addition, when the engine is shut off, there are some additional weird noises that seem to be coming from the same area. I can't tell where it is coming from. If anyone has any ideas, it would be greatly appreciated.
Thanks.
Old Mar 4, 2023 | 04:59 AM
Mmr1's Avatar
2013 glk 350
I’ve heard about Dyes for finding leaks in diesel, gasoline , cooling systems, etc that you pour into the fuel and use an infrared or ultraviolet light to trace leaks . Kits can be very cheap with light included. Amazon or your local auto store probably has these .
Old Mar 4, 2023 | 10:57 AM
John CC's Avatar
'17 GLS450, '14 GLK250, Grandpa's Roadster
Can't tell much from the video...
Old Mar 4, 2023 | 09:18 PM
calder-cay's Avatar
2014 GLK350 base model (active) ; 2001 E320 base (retired); 2001 Wrangler soft-top
I can't hear anything !!
EDIT : SEE my post #12 that follows ... the video is there
Old Mar 5, 2023 | 09:01 AM
Mmr1's Avatar
2013 glk 350
I guess my phone is broken, I don’t see a video posted
Old Mar 6, 2023 | 02:50 PM
andreigbs's Avatar
GLK 250
Can't see any vid, but off the top of my head, I'm thinking fuel filter area. Any recent service done? If so, what?
Any wetness or dampness around any of the 4 fuel injectors? Look for shiny/oily residue, as the smell itself may blanket the entire local area under the engine cover.
Old Mar 6, 2023 | 08:10 PM
John CC's Avatar
He hasn't checked back since he posted this thread.
Old Mar 6, 2023 | 10:57 PM
brliuy's Avatar
S / Cayenne / GLS
Mine is a turbine, I directly remove the front, it is conducive to heat dissipation, as for being able to smell the odor, I recommend cleaning the engine, there should be none. I smelled it when the oil was dissipating heat and leaking oil before, and then it was no longer after it was done
Old Mar 7, 2023 | 02:05 AM
slmskrs's Avatar
Weird that some people can see the video and others can't. I pasted a youtube video link. Maybe it has to be copy/pasted into a browser to work (unless the forum stripped it out). No service done recently and the last oil change was 3-4k ago (do it myself). The areas around the injectors were dirty, but generally, not specific to leakage (it had never been cleaned). I did clean it and don't see anything. But what we're smelling doesn't seem to be unburned diesel, but diesel exhaust. And it seems to be coming from the left top of the engine left of where the injectors are. I don't know what a number of those components are in that area.
It's probably hard to hear in the video but it almost sounds like a sucking sound (although that wouldn't explain the diesel fumes, so it could be something leaking out). I suspect if someone recorded the same video of the same engine without the noice and then compared the, it would be pretty obvious. Does anyone have any pictures or diagram of what all of the components, etc. are for our engine so I can work through each one?
Also, does anyone know if there is a mechanical linkage to manually give it throttle from inside the engine compartment like you can do on a gas car with the throttle plate? Or is it all electronic? I'd like to be able to rev it myself with a stethoscope rather than having my wife rev it from inside the passenger compartment.
Here's the link again (will have to be 'corrected' and pasted): http(ESS)://youtu.be/IigS-DXlR0I. (remove '(ESS)' and replace with 's')
Thanks.
Old Mar 7, 2023 | 05:14 AM
Mmr1's Avatar
2013 glk 350
You need to post a link that works. Get a dye Leak test kit, put dye in diesel and use the supplied UV light to find the fumes .
Old Mar 7, 2023 | 09:28 AM
John CC's Avatar
I don't think anyone can. I was joking about it. Here's a screenshot of what I see with Firefox. I also "quoted" your post and there was no link in the quote.
Old Mar 7, 2023 | 09:44 AM
calder-cay's Avatar
EDIT : the video is in this reply, at end
Weird that some people can see the video and others can't. .
Obsolutely EVERY person who has responded in here, cannot see a link or embedded video. You probably have it successfully posted in another forum, which is prob the folks who can see it
And now, you want folks to edit your malformed URL? Asking a lot
Here, let me give it a try (BTW - software engineer here with 35+ years experience)
Old Mar 7, 2023 | 11:05 AM
habbyguy's Avatar
2011 GLK 350 4Matic
Ack... those things are noisy! ;-)
What I do when I'm chasing something like this (sounds like a vacuum leak, but could be pressure escaping) is to get a few feet of hose of some sort, stick one end in my ear (loosely) and poke the other end around until it's obvious where it's coming from. Kind of the equivalent of a mechanic's stethoscope for non-mechanical noises (only even cheaper)! ;-)
Old Mar 7, 2023 | 02:40 PM
andreigbs's Avatar
GLK 250
There is no mechanical linkage to control the throttle from under the hood. Those days are gone.
I think by "diesel fumes" you're probably referring to diesel engine exhaust smell, which leads me to believe the EGR area is where it might be originating from. Could be something as simple as a loose bolt on the EGR valve where exhaust is escaping, or a cracked metal flex pipe in the EGR pathway.
Is there any sooty deposit anywhere there shouldn't be? That would help pinpoint the source.
Likely you've had the AEM work done, which means the entire exhaust system is covered for 4yrs/48k miles from that work. If you can't find the source, both from above or below, you may need to schedule a visit to your local stealership and tell them you're smelling exhaust fumes in the car. That's usually a red flag to get you in for service ASAP.
The only other thing I can think of is perhaps the PCV system, like the valve itself. If it's failed it can create too much pressure in the crankcase and can lead to blow outs in weak connections. In severe cases it can also blow out oil seals, so I would double-check the valve is clean and operating as supposed to.
Old Mar 13, 2023 | 10:53 AM
slmskrs's Avatar
Sorry for the delay guys; it's been one of those weeks/weekends.....I've got the dye; just haven't had a chance to put it in yet. I have a stethoscope; also haven't had time to pinpoint it further (wife and I just drive the other car in the meantime). It really sounds like sucking when the RPMs are dropping when I'm just standing there and having my wife rev the engine. I was hoping that someone would hear the sound and know what typically fails and would cause the noise and fumes in the general area and I'd go look at that. Hopefully I'll get to it this week..
Sorry about the youtube link. I could have sworn I posted it not only in the text, but in the field for links (and this is the only forum I've posted this on). I didn't realize no-one had been able to see/hear it.
Bummer you can't rev from the engine and have to have someone do it for you. But not surprising. I was just hoping....
I have not noticed a bunch of soot; in fact most of the engine is cleaner than I would expect. But I'll keep looking (with the stethoscope or hose).
Are you saying that this should be covered under the AEM warranty? That would be nice but I definitely want to be sure whatever it is is in fact covered before I take it in. They'll charge for just a glance my way if it is not covered. Where are the EGR and PVC valves on this engine? Anyone have a picture or diagram that shows the locations? I'm not recognizing anything but I don't know what they are supposed to look like on this engine. Don't know enough about diesels and suspect they are different and probably in different locations than my previous vehicles.
Old Mar 13, 2023 | 12:36 PM
andreigbs's Avatar
GLK 250
The EGR is on the driver's side of the engine, under the plastic-covered EGR cooler you're actually pointing to in your video. You can also see the metal flex pipe that looks like an S under the cooler. (Here's an exploded view of that side of the engine, with parts label and diagram OM651 EGR). The cooler is part# 10 and has a black plastic cover on top; the metal flex S-pipe is part# 150.
Having said that, and after playing the vid a few more times, it sounds like boost pressure escaping when letting off the throttle. It's quiet at idle because there's no pressure, but there is some being built up when you give it some Go pedal (even in Park or neutral).
So I'm wondering if you have a bad boost hose off the intercooler, or if you're recently replaced it and it may a loose clip or another tear in the hose itself.
If you've never checked the boost pipe, it's the most likely culprit. If you can rule it out for sure, then back to the EGR system.
The PCV valve is on top of the engine valve cover and towards the passenger side.
Edit: if the intercooler hose is bad, you would be getting exhaust fumes since those are mixed with fresh air when being forced back into the engine for combustion. The only way to make sure it's not the boost hose is to take it off and inspect it closely.
Old Mar 20, 2023 | 11:36 AM
slmskrs's Avatar
Thanks for the info. Really appreciate the explanation and the link. I'm only able to look at this about once a week. I didn't put the dye in yet because I noticed that even with the large container, there's only enough for a couple of gallons of diesel, and I have close to a full tank (and we're not driving it much). I got under the car and checked both hoses a couple of weeks ago and they both seemed okay (no holes, etc.) I didn't check to see if the clamps were tight. One of the hoses went years ago and since I didn't know what it was, I took the car to the dealer. It essentially blew out since there was an immediate loss of power whereas right now the power seems to be the same. I suspect they only replaced the hose that was bad, not both of them. Interesting on exhaust fumes with the hose being bad; makes sense. Maybe I should just replace both since I'm around 130k miles. I'll keep digging with the info you gave me!
Old Mar 20, 2023 | 09:31 PM
slmskrs's Avatar
Ignorant question: Which hose is the intercooler hose? Is it the big one on the left (driver's) side at the front, or the right (passenger) side at the front. I see two big hoses; I think the one that blew out last time was the one on the left (driver) side.
Old Mar 20, 2023 | 10:14 PM
John CC's Avatar
There are two: one from the turbo compressor outlet to the intercooler inlet and one from the intercooler outlet to the engine intake manifold.
Old Mar 21, 2023 | 07:46 AM
dzl_benz's Avatar
2015 GLK 250 BlueTec with AMG Sport package.
It is most likely your driver-side intercooler hose is failing. Take it off and inspect it closely. When mine failed, I couldn't see a tear, only felt it with my hand and after I took it off it was pretty obvious. Under boost pressure, the hose expands so it will be much louder than when idling. If there is a tear it will be at the top of the hose, in the area closest to the chassis.
Also, there is a small chance your vacuum tank may be split (black plastic thing you're touching in your video around 0:15) OR small hoses that connect to it may have been left unplugged. Check that too. Here is a vacuum system diagram
Old Mar 21, 2023 | 04:36 PM
andreigbs's Avatar
GLK 250
Good catch! Didn't even think about that one.
Old Apr 10, 2023 | 02:07 AM
slmskrs's Avatar
Sorry for the very long delay. I bought some dye and UV light to try to spot the leak; I got what I thought was a large amount of dye, but it's only enough to treat about three gallons of diesel. So we need to burn down through the tank, and we drive the EV so much, we still have a lot of diesel.
I was going to change both turbo hoses; bought both from Amazon. However, even though Amazon said they fit the GLK250, neither did. That said, I could not feel any crack or tear, so I removed both and inspected them. Neither are compromised/damaged or torn, so I put them back on.
Can anyone suggest other items to look at? Not sure what is what; here's a picture.
Thanks!!
