2010 GLK350 ESP fail
Old Mar 23, 2023 | 04:58 PM
rocketboy2000's Avatar
2010 GLK350
Hi there, love this site and everyone who participates!
we had a big snow and i pushed my 2010 GLK350 pretty hard to get through it. had dash ABS fail lights afterwards and suspected i may have damaged a wheel speed sensor. decided to give it a bit of time in case there was some ice in there or something and, indeed, the problem went away. did not have a scanner. that was three months ago.
now the engine lights come on and i get ABS and ESP failure dash warning messages. the exclamation triangle comes on as well but will go off if i disable ESP. i do have a BlueDriver scanner now which provides the following:
C2001
NOT PRESENT
The supply voltage of control unit "N30/4 (Electronic Stability Program control
unit)" is too high (overvoltage).
C2000
NOT PRESENT
unit)" is too low (undervoltage).
C1945
NOT PRESENT
There is an internal fault in component "N30/4 (Electronic Stability Program
control unit)".
C1944
NOT PRESENT
control unit)".
C1001
NOT PRESENT
control unit)".
P0856
MIL/PRESENT
Traction Control Input Signal
my question is, could this still be a wheel sensor issue? i would rather not have to take each wheel off to check but will get a probe camera if its possible this is the problem and am able to see with such a device.
or, am i looking at a replacement of the N30/4 unit?
any insight appreciated!
Old Mar 23, 2023 | 07:00 PM
Silver Shadow's Avatar
2006 Alfa Romeo Brera, 2010 GLK350, 2018 BMW 640i GT, 1997 Subaru SVX, 2012 Moto Guzzi Norge GT8V
I have a very similar issue which started a couple of days ago. A bunch of codes and warnings. C1132, C3270, P1425, U140D, U140C, I had about a dozen yesterday. It even went into limp mode a couple of times. I have a C1132 RR sensor code. I have a sensor to install tomorrow to see if it works.
I replaced the battery because it failed a load test but that made no difference. I also cleaned the ABS Module connecters thoroughly which also did not help.
Old Mar 24, 2023 | 12:43 AM
Odd Piggy's Avatar
2021 GLB250 FWD, 2023 GLA250 FWD, 2013 C250, 2015 GLK350, 2005 ML350SE, 2003 E320
That looks like an ESP control unit failure. But before replacing that expensive part, crawl underneath (engine off, in park, parking brake on, wheels chocked) and look for a broken wire on one or more of the wheel speed sensors.
Old Mar 24, 2023 | 01:47 PM
andreigbs's Avatar
GLK 250
Good advice so far. I would add to check the reluctor ring. When those go bad, you'll get similar errors including limp mode.
Old Mar 26, 2023 | 05:00 AM
I replaced the RR ABS sensor, no change.
Old Mar 26, 2023 | 11:42 AM
Odd Piggy's Avatar
May be the ABS control unit. I hesitate to tell you to change it because chasing phantoms can be frustrating and expensive. I’m not an MB tech. You have a number of codes, some of which may not be related.
Old Mar 26, 2023 | 11:57 AM
BTW the ABS and ESP control module is the same part.
Old Mar 27, 2023 | 09:26 AM
Mmr1's Avatar
2013 glk 350
With high and low voltage codes be sure it’s getting proper voltage , bad ground happens often . Be sure the battery produces proper power.
Old May 2, 2023 | 08:28 PM
I fixed mine today. 6 hours with a few headaches. The problem was the ABS tone/reluctor ring. They aren't sold separately anymore for the GLK but I cross referenced the part number and got the right one on Amazon for $20 CAD. Part number is 2303570182.
Old May 11, 2023 | 05:13 PM
W205C43PFL's Avatar
It is always the most simple things, the ones that you least expect that fails causing issues, glad you figured it out, thanks for your update and the part number.
