Wiper parking positions
(This is not new; it's been like this since I got the car.)
Never had a reason to troubleshoot the wipers - they work as designed and when sitting in the front seat, they are not visible.
I was just offering what ours looks like - no issues here.
However, I do notice now that the passenger side looks a bit higher ... thanks for pointing it out
Old Piggy: my 2014 was made about a week after they updated the arms. I found that out the hard way...
Do I need a puller to move the arm? I found some alignment marks in the WIS, but I can't see them with the windshield dripping wet, so I don't even know where I stand. It's supposed to rain for about another 38 days, I think...
My ‘15 had the black appearance edge around the window and the tip of the right side wiper could be seen above it. That couldn’t possibly be correct, right?
I tried to move it down and wound up with it parking too low. Frustrated, I put it back and left it in the original position.
I have a puller, but don’t think I needed it. But the car was probably only 6 months old. I didn’t even think to look for alignment marks.
but it went through a few windshields.
The Mercedes arm puller is a very specific little device, but any small 2 arm puller should work.
The yellow dot on the blade itself is a UV detector. It starts out white, and when it turns bright yellow you're supposed to replace the blade. Valeo blades have them, too, and I suspect they are the OEM.
I have a battery terminal puller that should work, but it is at a different location. However, it sounds like I have a choice between where it is now or too far down...
Good luck on the adjustment...
