GLK 350 crankshaft position sensor code
Also - Mercedes now has online replacements called Star Parts that are discounted from the standard MB parts list, sometimes significantly. Example: M271.860 water pipe (common failure) - Star Part $85; - parts counter walk-in price $188. Packaging is different but both have the same MB part number molded into the part.
But everyone has their own comfort level.
Do not buy electrical parts from a source that is not a dealer. Resist the temptation to rationalize oneself in a different direction.
https://mbworld.org/forums/e-class-c...-rattle-4.html
Seems the course of events are:
Startup rattle from chain slap due to bad tensioner or check valve behind tensioner.
Then you get the camshaft position code
And it's probably going to be a cam adjuster or two.
Vice grips time I'm guessing..
... "hopefully we don't screw it up"
... "seems to be within spec"
@GLKwanter
Have you considered doing the "remove front cam cover and turn engine with breaker bar" test?
Some partially useful information and video content along with truly annoying presentation.
Certainly worth a watch and I also appreciate alternative methods and use of non MB tools but... still painful to watch/listen to, for me.
