GLK 350 crankshaft position sensor code
Well I got my wish..
2013 GLK 350 135k miles. I've owned it for a 1000 miles and noticed an intermittent check engine light today. Only code came back camshaft position sensor.
It's also got the rough idle at startup MB made a bulletin about. Can't find it ATM, but specifically remember it saying No further damage expected from this issue. This thread is how I diagnosed that issue that.. I assume many just live with?
https://mbworld.org/forums/m-class-w166/506780-making-weird-noise-startup-please-help-2.html
..but since everything's in the same relative vicinity I was wondering what MB world thought. Did the rough idle cause the sensor to start going bad? I've seen some say to be very picky about the oil. Is that it?
So far that light for code camshaft sensor has come on and went off one time.
Thoughts?
Last edited by GLKwanter; Jun 12, 2023 at 10:24 AM. Reason: Title should say cam not crank shaft
I have had direct experience with a failing CPS on our 2001 Jeep Wrangler (somewhere in 120k-130k miles). Ran very sporadically... starting it was a gamble whether it would fire right up or would take numerous attempts. Sometimes if you let it sit for 15 minutes, it would then fire right up.
Anyway, I replaced the CPS... took about an hour total ... but keep in mind, on the Wrangler, it's a straight six, and it sits up high, so crawling under and reaching the CPS was a breeze. After replacing, start ups and running is as normal.
But like I said, not sure about the GLK, but in general, I'd replace it "now", rather than later.
The Carfax shows the oil was changed 3,000 mi ago, but it's not as clean as I would suspect and then it was just put up for sale at the dealership I bought it at. I don't figure they used great oil, and I should obviously change it if I feel this way. I ponder this could cause a CPS to go bad.
Whew!! I thought "four" CPS ?!?!?! That can't be !!
Okay, so ... good that got clarified !
On to the next challenge...
The rough startup idle would be great to fix myself, but it's a lot of work I'd have to buy some tools and if it's 'not going to cause further issues' I doubt I'll bother. But I wonder if the 2 second vibration could shorten the life of a Cam PS..
Vibration is from misfire or worn engine mounts. This engine is smooth as silk when plugs, coils and sensors are in good order. MB engine mounts are like jello which is good for comfort but bad for longevity.
If the car is a RWD variant, it's an easy 2-hour job (though it does require a special tool or two). If it's a 4Matic, it's a MUCH bigger job (8-10 hours). I did a youtube video on the difference between worn-out motor mounts and new ones (I won't post a link here because it insists on showing it as an embedded screen in the post). If you can't find it just search "Mercedes GLK 350 X204 - New vs. Worn Out Motor Mounts".
Oil check valve is a well known and documented job that is needed on this engine.
This engine is smooth as silk when all components are nominal. If there is a vibration then something is non-nominal.
Edit
It is exactly as that guy video recorded his glk startup in the post I linked
